DAC and WKP pins
If I want to use the pins as GPIO, do I address them in code as DAC and WKP or do they have alternate names?
If I’m not mistaken, you can use those names, or count on. Either should work I believe.
You can also address them as A6 & A7 (suppose that’s what Moors meant with count on :blush:)
Thanks for the info guys.
