Customer full_name
It looks like the full_name field was depreciated as I’m not getting the return when the list customers api is called. Is there any reason why this is no longer available? Any plans to add more field options for customer info?
Hi, what indications are you getting that it has been deprecated?
So when I make the the GET /v1/products/:productIdOrSlug/customers I’m not getting the “full_name” value back
Yeah, that’s not great. I’ll talk to the dev team and see if I can find a workaround for you.
What product are you using it in?
i just DM the product numbers
Hi Oraclerouter, I looked into it and none of the customers have the full_name set and that’s why this field is not present when listing them. I will talk to the documentation team about clearly marking this as deprecated.
