CPU (and other) temps
Since putting my tachyon in a case I've noticed it's felt quite warm - I'm sure it's well within spec but I can't seem to get to a simple high-level temperature reading in either particle-console or CLI. lm-sensors/hddtemp packages are included by default but the output of sensors only gives me battery temp/voltage/current readings.
Walking the thermal zones in /sys/class/thermal gives me 87 lines of output... amongst those I can see zones that are named things like modem-lte-sub6 and cpu-0-0-step .... any clues on useful/meaningful ones to check?
closest I can guess is
/home/particle/thermals.sh 2> /dev/null | grep -i uss
gpuss-0-step        51.0°C
gpuss-1-step        49.8°C
cpuss-0-usr         55.8°C
cpuss-1-usr         53.9°C
gpuss-0-usr         51.0°C
gpuss-1-usr         49.4°C
Hey Zedstarr,
I typically used 'sensors' to view temperature zones but it will output the same as /sys/class/thermal typically. in terms of which is important, that isn't something that is easy to document but I'll get it onto the list! The system automatically turns itself 'down' when it gets warm so the output is that CPUs will be restricted in CPU temperature and the modem throughput will be reduced all the way up to 100C operating temperature so there isn't much to worry about.
You can keep the temperature down by setting the cpu governors to change the behaviour and use hot plug to remove those cores - a lot more to that than I can write here quickly, but it all works :slight_smile:
Nick.
sensors only outputs 5 zones for me - none of which are cpu/gpu, hence why I went looking in /sys/class/thermal
wireless-isa-0000
Adapter: ISA adapter
in0:              N/A  (max =  +0.00 V)
curr1:       575.00 mA (max =  +0.00 A)
usb-virtual-0
Adapter: Virtual device
temp1:        -40.0 C
battery-virtual-0
temp1:        +25.0 C
usb-isa-0000
in0:          68.03 V  (max =  +0.00 V)
temp:         -40.0 C
curr1:         0.00 A  (max =  +0.00 A)
battery-isa-0000
in0:           4.09 V  (max =  +4.20 V)
temp:         +25.0 C
curr1:       -106.00 mA
Looking into this - we use a script that we can open source here and will circle back!
I am also seeing 87 thermal zones (and 45 cooling devices). and then only 5 entries in sensors none of which are the CPU. Sensors was also not preinstalled and the thermals.sh script is not present.
Is it possible to at least get some indication of which zones are vaguely applicable
Just following up here - I’ll chase this down and get back! I had delegated but not followed up - my bad. Thanks!
Here’s the range of thermals I observe with Tachyon in a 3D-printed case (used hardinfo). Some negative and zero thermals values were removed from the list.
It would be good to match the thermal zones to the sensor types.
-Sensors-
../../battery/in0 Voltage 4.13V
../../battery/temp1 Temperature 27.00°C
../../thermal_zone85/temp1 Temperature 27.00°C
../../usb/in0 Voltage 5.02V
thermal/thermal_zone0 Temperature 42.06°C
thermal/thermal_zone1 Temperature 39.00°C
thermal/thermal_zone2 Temperature 38.00°C
thermal/thermal_zone3 Temperature 2.00°C
thermal/thermal_zone4 Temperature 2.00°C
thermal/thermal_zone5 Temperature 2.00°C
thermal/thermal_zone6 Temperature 2.00°C
thermal/thermal_zone7 Temperature 39.00°C
thermal/thermal_zone9 Temperature 2.00°C
thermal/thermal_zone10 Temperature 2.00°C
thermal/thermal_zone11 Temperature 2.00°C
thermal/thermal_zone12 Temperature 2.00°C
thermal/thermal_zone13 Temperature 2.00°C
thermal/thermal_zone14 Temperature 27.00°C
thermal/thermal_zone15 Temperature 27.00°C
thermal/thermal_zone16 Temperature 27.00°C
thermal/thermal_zone17 Temperature 41.30°C
thermal/thermal_zone18 Temperature 42.00°C
thermal/thermal_zone19 Temperature 27.00°C
thermal/thermal_zone20 Temperature 43.40°C
thermal/thermal_zone21 Temperature 43.40°C
thermal/thermal_zone22 Temperature 43.40°C
thermal/thermal_zone23 Temperature 42.60°C
thermal/thermal_zone24 Temperature 42.20°C
thermal/thermal_zone25 Temperature 41.80°C
thermal/thermal_zone26 Temperature 43.00°C
thermal/thermal_zone27 Temperature 42.20°C
thermal/thermal_zone28 Temperature 43.80°C
thermal/thermal_zone29 Temperature 43.00°C
thermal/thermal_zone30 Temperature 43.40°C
thermal/thermal_zone31 Temperature 43.00°C
thermal/thermal_zone32 Temperature 42.00°C
thermal/thermal_zone33 Temperature 42.00°C
thermal/thermal_zone34 Temperature 41.30°C
thermal/thermal_zone35 Temperature 41.30°C
thermal/thermal_zone36 Temperature 42.40°C
thermal/thermal_zone37 Temperature 42.80°C
thermal/thermal_zone38 Temperature 42.40°C
thermal/thermal_zone39 Temperature 42.00°C
thermal/thermal_zone40 Temperature 42.00°C
thermal/thermal_zone41 Temperature 43.00°C
thermal/thermal_zone42 Temperature 43.00°C
thermal/thermal_zone43 Temperature 43.40°C
thermal/thermal_zone44 Temperature 43.40°C
thermal/thermal_zone45 Temperature 42.20°C
thermal/thermal_zone46 Temperature 43.40°C
thermal/thermal_zone47 Temperature 43.40°C
thermal/thermal_zone48 Temperature 42.20°C
thermal/thermal_zone49 Temperature 41.80°C
thermal/thermal_zone50 Temperature 42.20°C
thermal/thermal_zone51 Temperature 42.20°C
thermal/thermal_zone52 Temperature 43.40°C
thermal/thermal_zone53 Temperature 43.00°C
thermal/thermal_zone54 Temperature 43.00°C
thermal/thermal_zone55 Temperature 43.00°C
thermal/thermal_zone56 Temperature 42.80°C
thermal/thermal_zone57 Temperature 42.40°C
thermal/thermal_zone58 Temperature 42.40°C
thermal/thermal_zone59 Temperature 41.70°C
thermal/thermal_zone60 Temperature 41.70°C
thermal/thermal_zone61 Temperature 42.80°C
thermal/thermal_zone62 Temperature 42.80°C
thermal/thermal_zone63 Temperature 42.40°C
thermal/thermal_zone64 Temperature 41.30°C
thermal/thermal_zone65 Temperature 41.70°C
thermal/thermal_zone66 Temperature 42.00°C
thermal/thermal_zone67 Temperature 42.40°C
thermal/thermal_zone68 Temperature 37.00°C
thermal/thermal_zone77 Temperature 41.93°C
thermal/thermal_zone78 Temperature 8.44°C
thermal/thermal_zone80 Temperature 0.00°C
thermal/thermal_zone81 Temperature 0.00°C
thermal/thermal_zone82 Temperature 0.00°C
thermal/thermal_zone83 Temperature 0.00°C
thermal/thermal_zone84 Temperature 4.08°C
thermal/thermal_zone85 Temperature 27.00°C
