Core with poor wifi connects every 7 minutes
I am pushing the boundaries of the wifi range, but for now it is unavoidable. For a while everything was working ok, but recently the units has been dropping connection. I moved a few things and it got better, but still disconnects, but then somehow it reconnects every 7 minutes, on the dot. Is there a reason for this? Can I get it to try more frequently than seven minutes? Just looking for some clarification. I am logging data on power usage, so in its current state it isn’t very useful.
What’s the core doing when it reconnects? Is it a red SOS then reset causing the reconnection or a cyan flash then reconnect?
Also what is your code doing? Is there connections at set time intervals?
Hi @officeboy
If you have a range problem that you cannot move things to fix, why not get a u.fl Core and high-gain external antenna that you can point at your router/access-point?
A good antenna can make up for a lot of range problems in stationary applications.
You know I have walked by it and seen it blinking blue or green and figured that was the issue. But after watching it for a 7 min cycle, it just kept “breathing cyan” and then had a funny little pulse (like a skipped beat) and went back to breathing. I am disabling the local screen update, and re-flashing to see how stable it is. The project is https://github.com/officeboy/EmonCore if you care to review my code.
