Core stuck cyan flashing after sFLASH_EraseBulk()
My core is stuck cyan flashing after using sFLASH_EraseBulk(). Did I erase parts of the firmware? I assumed this so I have been downloading Spark firmware v0.3.4 from GIT and using:
dfu-util -d 1d50:607f -a 1 -s 0x00020000:leave -D core-firmware.bin
to flash it back on but it still does not get over cyan flashing.
Am I missing something to bring it back to normal?
You may have overwritten the keys stored in flash. Someone else can weigh in but I’d suggest a spark cli keys doctor command which might fix it. See https://github.com/spark/spark-cli#spark-keys-doctor
If I use the key doctor with my CoreID I get some errors:
Error saving key from core... Error: Command failed: unable to load Private Key
140735278523232:error:0D07207B:asn1 encoding routines:ASN1_get_object:header too long:asn1_lib.c:153:
Error saving key to core... Error: Command failed: unable to load Private Key
Make sure your core is in DFU mode (blinking yellow), and that your computer is online.
Error - Error: Command failed: unable to load Private Key
Hi @MarkusL,
The CLI is trying to do you a favor by making sure your key is backed up before overwriting it.
Try writing the key manually with:
dfu-util -d 1d50:607f -a 1 -s 0x00002000:leave your_private_key.der
David
The key doctor creates 2 files with .der ending,
pre_<my device>_new.der
<my device>_new.der
which one?
UPDATE: tried both and still flashing…
Hi @MarkusL,
You want the new one, and not the “pre” one (that’s the old one).
Once you’ve written the key, send it to the cloud with:
spark keys send YOUR_CORE_ID CORE_KEY.pub.pem
David
no luck, same cyan flashing. This is the console out:
dfu-util -d 1d50:607f -a 1 -s 0x00002000:leave -D core.der
dfu-util 0.7
Copyright 2005-2008 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2012 Tormod Volden and Stefan Schmidt
Filter on vendor = 0x1d50 product = 0x607f
Opening DFU capable USB device... ID 1d50:607f
Found DFU: [1d50:607f] devnum=0, cfg=1, intf=0, alt=1, name="@SPI Flash : SST25x/0x00000000/512*04Kg"
Claiming USB DFU Interface...
Setting Alternate Setting #1 ...
Determining device status: state = dfuERROR, status = 10
dfuERROR, clearing status
dfuIDLE, continuing
Device returned transfer size 1024
No valid DFU suffix signature
Warning: File has no DFU suffix
DfuSe interface name: "SPI Flash : SST25x"
Downloading to address = 0x00002000, size = 608
File downloaded successfully
Transitioning to dfuMANIFEST state
Error during download get_status
and this:
spark keys send <coreID> core.pub.pem
attempting to add a new public key for core <coreID>
submitting public key succeeded!
It downloaded to the flash but you might have wiped out more :stuck_out_tongue:
So then how to restore the missing pieces?
@MarkusL,
There are a couple of things to be restored since i have no idea what parts of the external flash did you erase.
Having Spark-cli will be super useful
1.) Restore factory firmware
`spark flash --factory tinker``
2.) Restore Spark :cloud: public key
spark keys server cloud_public.der
https://s3.amazonaws.com/spark-website/cloud_public.der
3.) Restore core public keys with
spark keys doctor CORE_ID which you probably have done
Once that’s done, factory reset the core and it should work well :wink:
@kennethlimcp YOU ROCK!
Thanks - core is alive again!
