Core Internal Temperature Sensor
I copied this example:
I’m getting around 42C on one core and 47C on another.
I am looking at using this value, together with the RSSI Signal strength, as a core ‘health’ indicator.
const uint16_t V25 = 1750;// when V25=1.41V at ref 3.3V
const uint16_t Avg_Slope = 5; //when avg_slope=4.3mV/C at ref 3.3V
//VCC and VREF = 3.3V; ADC_value = 4096
//V25 = 1.41V; ADC_Value=1750 (calculated = (1.41/3.3)*4096)
//Avg_Slope = 4.3mV ADC_value=5 (calculated = (0.0043/3.3)*4096)
void CpuTempInit()
    //enable ADC1 clock
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
    ADC_InitTypeDef ADC_InitStructure;
    //ADC1 configuration
    //select independent conversion mode (single)
    ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
    //We will convert single channel only
    ADC_InitStructure.ADC_ScanConvMode = DISABLE;
    //we will convert one time
    ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
    //select no external triggering
    ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
    //right 12-bit data alignment in ADC data register
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
    //single channel conversion
    ADC_InitStructure.ADC_NbrOfChannel = 1;
    //load structure values to control and status registers
    ADC_Init(ADC1, &ADC_InitStructure);
    //wake up temperature sensor
    ADC_TempSensorVrefintCmd(ENABLE);
    //ADC1 channel16 configuration
    //we select 41.5 cycles conversion for channel16
    //and rank=1 which doesn't matter in single mode
    ADC_RegularChannelConfig(ADC1, ADC_Channel_16, 1, ADC_SampleTime_41Cycles5);
    //Enable ADC1
    ADC_Cmd(ADC1, ENABLE);
    //Enable ADC1 reset calibration register
    ADC_ResetCalibration(ADC1);
    //Check the end of ADC1 reset calibration register
    while(ADC_GetResetCalibrationStatus(ADC1)){}
    //Start ADC1 calibration
    ADC_StartCalibration(ADC1);
    //Check the end of ADC1 calibration
    while(ADC_GetCalibrationStatus(ADC1)){}
	CpuTempInit();
	Serial.begin(9600);
    //Start ADC1 Software Conversion
    ADC_SoftwareStartConvCmd(ADC1, ENABLE);
    //wait for conversion complete
    while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC)){}
    //read ADC value
    uint16_t AD_value=ADC_GetConversionValue(ADC1);
    //clear EOC flag
    ADC_ClearFlag(ADC1, ADC_FLAG_EOC);
    //printf("\r\n ADC value: %d \r\n", AD_value);
    uint16_t IntTemp = (uint16_t)((V25-AD_value)/Avg_Slope+25);
    Serial.println(IntTemp);
    Delay (2000);
