Hey there,
I’ve set up a core to blow a train whistle via digitalWrite(pin, HIGH);
when a DO button is pushed. Unfortunately, it doesn’t work reliably. It seems to work only immediately after startup/reflashing and will also work somewhat unreliably (with delays or not at all) shortly after startup/reflashing. I looked at the log for the DO publish event recipe and the recipe does seem to be getting triggered everytime.
I’m not really sure what the Core is seeing/doing as it is currently installed and not easily accessible. So I’m hoping to get some help for a better setup or some debugging tips…
In setup:
Spark.subscribe("HONK", hornHandler, MY_DEVICES);
added the following handler:
void hornHandler(const char *event, const char *data) {
honk();
allOn();
i++;
Serial.print(i);
Serial.print(event);
Serial.print(", data: ");
if (data)
Serial.println(data);
else
Serial.println("NULL");
Spark.publish("triggered", data, 60);
Function to toot the whistle:
void honk() {
relayOn(horn);
delay(1500);
relayOff(horn);
delay(1500);
relayOn(horn);
delay(1500);
relayOff(horn);
I was thinking maybe the Core is going to sleep and disconnecting from the network after sometime and just not reconnecting properly, but who knows…
