I wanted to use my old CORE to try-out some programs. But I don’t succeed to connect my device on internet. Is this not possible anymore ?
For my test-proposals, it’s OK if I can program my CORE only with an USB-connection, without wifi. Is there a possibility to work that way ?
thx for your answer ! jk
It should still be very much possible to use your Cores.
You can flash a binary using the CLI, so that should be no problem either. Just make sure you use the appropriate "no internet" bits of code or it will keep on trying to connect.
Thx for your advice. I have to try the proposed way. wkr jk
