Controller Protocol for DC12V LC8808 Pixel LED
electron
Tags: #<Tag:0x00007f1ca3b3a120>
#1
This post was flagged by the community and is temporarily hidden.
#2
You posted unter the Raspberry Pi category but yet have the topic tagged electron :confused:
What is it now?
#4
ok,
how about just the pdf of the datasheet?
http://addressable-led.com/UploadFile/upi/file/20190318/LC8808-LED.pdf
#5
Not sure what you mean with that, but the protocol seems quite similar to the legacy NeoPixel protocol (aka WS2811/WS2812/APA-104/SK6812) which uses only one data line with critical timing where the duty cycle of a single bit is used to distinguish between 0 and 1
The secondary data line SDI2 is not used as clock (as known from APA102) but as a fail safe to “skip” single dead LEDs.
Also these LEDs require min. 4V logic level but RPi and Electron (you still haven’t clarified) will only give you 3.3V.
unlisted #7
