I have ported a library that contains the following structure:
firmware/utility
The “utility” folder contains includes that are referenced by a main file in “firmware”
However, when I contribute the library and include the library in a test sketch and compile it fails because it can’t find the reference to the “utility” folder.
Do libraries not allow subfolders inside firmware? Is there a way of getting this to work properly?
@gotnull, I had this problem as well. You can try changing the references to your libraries to:
myLibraryname/utility/filename (changing myLibraryname and filename of course)
I don’t develop in the web IDE because of external library “issues” such as these. Instead I use Spark CLI and DEV. Let me know how it goes. I had the porting of the u8glib on my list of todo and just didn’t get to it yet. A link to your github repo would be great!
I’ve tried changing the references, but now I’m getting all sorts of compilation errors. I think for the time being I’m gonna give up and move onto something else.
If you manage to port the u8glib library that’d be awesome. Please let me know
