Hi guys,
First project in a while using the Particle platform. I need to access a hosted CSV file using a webhook. I’ve been able to do this for a small amount of data, but I now need to get a CSV that contains about 3000 ASCII characters. When I go into the event stream, I can see that data broken up into multiple events. I can’t work out how to handle the multiple callbacks that get triggered for each of these. I need to parse and process the incoming data, but I’m having problems getting the number of characters passed in each callback. What is the best way to do this?
