If you want the simplicity of the Cloud but you want it on your own server, we’ll be releasing an open source version of the Cloud designed for quick and easy deployment. I want to send my device data to MS Azure using CoAP.can I or do I have to use the open source version you are talking about or you have a suggestion on how to connect to Azure?
Hi @osmond1114,
You can certainly run C# or other code on your Azure server to connect to the Spark API, and you can also run the open source Spark Server package there as well. @kareem613 wrote a great .Net wrapper for the API here:
David
