Hello
I’m trying to connect a hall sensor to the photon board which would then act as a trigger for increasing the brightness of a neopixel/s. I have managed to connect the neopixel and set up a code to change its color using the IFTTT app. I now want to integrate a hall sensor into it which would then notch up the brigtness of the neopixel by a set amount as it detects a magnetic field. I am unsure as to how to combine the hardware as well as the code. I tried locating some code for hall sensors but couldnt find any for photon and I am not familiar with coding as much. Please help me!
Here are my two sets of codes, first one for setting the color and second one for the hall sensor.
#include "neopixel/neopixel.h"
#define PIXEL_COUNT 24
#define PIXEL_PIN D6
#define PIXEL_TYPE WS2812B
// vars to split array
const unsigned int BUFFER_SIZE = 64;
char paramBuf[BUFFER_SIZE];
// Init the LED strip
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, PIXEL_TYPE);
// Particle.function("red", setRed);
// Particle.function("green", setGreen);
// Particle.function("blue", setBlue);
Particle.function("setColor",setColor);
strip.begin();
void setStripColor(int red, int green, int blue) {
for (int i=0; i < PIXEL_COUNT; i++)
strip.setColor(i, red, green, blue);
strip.show();
// int setRed(String r) {
// red = r.toInt();
// setStripColor();
// return red;
// int setGreen(String g) {
// green = g.toInt();
// setStripColor();
// return green;
// int setBlue(String b) {
// blue = b.toInt();
// setStripColor();
// return blue;
int setColor(String paramStr) {
// Convert String to char array.
paramStr.toCharArray(paramBuf, BUFFER_SIZE);
// Split string by the ',' delimiter. Expect three int.
char *pch = strtok(paramBuf, ","); // Create string tokenizer.
int red = atoi(pch); // Convert first token to int.
pch = strtok (NULL, ",");
int green = atoi(pch);
int blue = atoi(pch);
setStripColor(red, green, blue);
return 1;
#include <neopixel.h>
//#include <Adafruit_NeoPixel.h>
//define neopixel number
#define NUM_LEDS 1
int waitTime=400; // delay before it turns into red again
#define PIN D6
#define PIXEL_TYPE WS2812//neopixel
#define hallPin D0
//output of hall sensor
int hallState = 0; //initial state
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS,PIN,PIXEL_TYPE);
Serial.begin(115200);
pinMode(hallPin, INPUT); //setting the hall sensor as the input for the neopixel
strip.begin(); //initiates the data going to the neopixel
strip.show();
void loop() //loop to detect the input from the sensor
hallState = digitalRead(hallPin);
Serial.println(hallState);
if (hallState == 1 )
int i;
uint32_t c;
c= strip.Color(10,10,10);
for(uint16_t i=0; i<strip.numPixels(); i++)
strip.setPixelColor(i,c);
strip.show();
// turn the LED on at a regular state
//strip.setPixelColor(0, 10,10, 10); //dull white
else {
//strip.setPixelColor(0, 255, 255, 255); //bright white
int i;
uint32_t c;
c= strip.Color(255,255,255);
strip.show();
//strip.show();
//delay(waitTime);
// wait
