Connect with Grove modules
Hi all,
Are there anyone who successfully connect Core with Grove?
I’d like to turn on/off lamp with a Grove Relay.
Please share your experience and story.
Michael
As far as the relay goes, it seems to be compatible. While trying to control it via Grove (I2C ?), did you add the pull up resistors? I haven’t used Grove myself.
It works well. Just plug in and play! You can done it in 30s. :smile:
