I am trying to control a mosfet that requires an open drain to switch off the power to peripherals. I am using pin A1 to control the circuit.
Turning it on works using pinMode(pin, OUTPUT)
and digitalWrite(pin, LOW)
However, using digitalWrite(pin, HIGH)
results in the switched power initially going off then being switched on again. I understand from the electronics guys that I need to set the A1 pin into open drain mode and the way to do this (from another thread) is to call a custom pinMode()
routine.
void Pin_Mode_Open_Drain(pin_t pin)
STM32_Pin_Info* PIN_MAP = HAL_Pin_Map();
GPIO_TypeDef *gpio_port = PIN_MAP[pin].gpio_peripheral;
pin_t gpio_pin = PIN_MAP[pin].gpio_pin;
GPIO_InitTypeDef GPIO_InitStructure = {0};
if (gpio_port == GPIOA)
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
else if (gpio_port == GPIOB)
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
else if (gpio_port == GPIOC)
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE);
else if (gpio_port == GPIOD)
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
GPIO_InitStructure.GPIO_Pin = gpio_pin;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
PIN_MAP[pin].pin_mode = OUTPUT;
GPIO_Init(gpio_port, &GPIO_InitStructure);
This is not working - any clues as to why? Thanks
