I run this command inside my project directory.
particle compile photon --saveTo software.bin
it gives me error
"I couldn’t find that: --saveTo"
Is there any alternative command to this?
it gives me error
Try particle compile photon * --saveTo software.bin
It’s missing the parameter of the directory to compile for.
Actually I tried that also.
I couldn’t find that: *
Works for me. Are you in the directory containing the files?
KENMBP:oled-dht22 kennethlimcp$ particle compile p * --saveTo x.bin
Compiling code for photon
Including:
Adafruit_GFX.cpp
Adafruit_GFX.h
Adafruit_SSD1306.cpp
Adafruit_SSD1306.h
PietteTech_DHT.cpp
PietteTech_DHT.h
oled-dht22.ino
pushing file: Adafruit_GFX.cpp
pushing file: Adafruit_GFX.h
pushing file: Adafruit_SSD1306.cpp
pushing file: Adafruit_SSD1306.h
pushing file: PietteTech_DHT.cpp
pushing file: PietteTech_DHT.h
pushing file: oled-dht22.ino
Memory use:
text data bss dec hex filename
18980 1220 584 20784 5130 /spark/compile_service/shared/workspace/6_platform_6_20_1/firmware/2defb9b2c2425813d0e0399e005ba656b2b1683ea2d0b7a9ff8870378696/2defb9b2c2425813d0e0399e005ba656b2b1683ea2d0b7a9ff8870378696.elf
grabbing binary from: https://api.particle.io/v1/binaries/56670323acd9a1043a1fc7c2
Compile succeeded.
Saved firmware to: /Users/kennethlimcp/Desktop/particle/oled-dht22/x.bin
I’d prefer this version
particle compile p . --saveTo x.bin
as the single dot (.
) denotes the current directory more explicitly than the astersik (*
) which usually denotes a multi-place-wildcard.
@kennethlimcp I think * not works because of Windows OS.
@ScruffR thanks for the solution it worked for me.
Also particle compile p *.* --saveTo x.bin
works
