I’d be interested in what speeds other people are getting on commands issued to particle boards.
I built a lamp on a particle board. It uses 2 neopixel rings (RGBW), which can get controlled using a remote (openhab, so I can control from android, my pebble watch, and some other remotes)
It worked nicely BUT wow was it slow. I was seeing about 6second delays between telling the lamp to turn on, and it actually turning on.
I re-jigged it to use cloudMQTT instead and it’s much faster (less than 1 second). It could be on local mosquitto but I’m avoiding running a server right now.
This is easy to test with the Tinker app and a phone (or curl if you like). For me the time is around 500-600ms (around 1/2 of a second).
When I measure the round-trip time to any AWS host (like those used by Particle) it comes out about the same so I don’t think the Particle cloud code is the rate determining step in the process.
