Yes, it would, but I’ve made wrong assumptions before.
I’m still working on getting the latest particle lib to work, but the this spark code works. Many thanks to everyone that helped me get on the right path!
Just wanted to update the code, in case it will help anyone else. This code isn’t optimized and I apologize for its sloppy nature. I’ll clean it up later.
This page will load and automatically run the java start() function. I’ve shorten the actual deviceID and Access_Token codes, but otherwise this is the code that is currently working. Thanks again for everyone’s help!
<html>
<head>
<title>Current Location</title>
<meta name="viewport" content="initial-scale=1.0">
<meta charset="utf-8">
<style>
html, body {
height: 100%;
margin: 0;
padding: 0;
#map {
height: 100%;
</style>
</head>
<body onload= "start()">
<span id="temp"></span><br>
<span id="tstamp"></span><br>
<div id="map"></div>
<div id="capture"></div>
<script>
var map;
function initMap() {
map = new google.maps.Map(document.getElementById('map'), {
center: {lat: 39.833, lng: -98.585},
zoom: 8
function ConvertDMSToDD(days, minutes, seconds, direction) {
var dx = minutes + "." + seconds;
var dl = (Number(dx)/60);
var dd = Number(days) + dl;
dd = parseFloat(dd);
if (direction == "S" || direction == "W") {
dd = dd * -1;
} // Don't do anything for N or E
return dd;
function doh(str) {
var res = str.replace("'","");
str = res;
str = res;
var constr = str.split(",");
var latstr = constr[0].replace(" ",".");;
var longstr = constr[1].replace(" ",".");
var latdir = latstr.charAt(0);
var longdir = longstr.charAt(0);
res = latstr.replace("+","");
latstr = res;
res = longstr.replace("-","");
longtr = res;
res = longstr.replace("+","");
longstr = res;
longstr = res;
if (latdir == "+")
latdir = "N";
else
latdir = "S";
if (longdir == "-")
longdir = "W";
else
longdir = "E";
var latpart = latstr.split(".");
var longpart = longstr.split(".");
console.log(latstr);
console.log(latpart[0])
console.log(latpart[1])
console.log(latpart[2]);
console.log(latdir);
console.log(longstr);
console.log(longpart[0]);
console.log(longpart[1]);
console.log(longpart[2]);
console.log(longdir);
var lat = ConvertDMSToDD(latpart[0],latpart[1],latpart[2],latdir);
console.log(lat);
var long = ConvertDMSToDD(longpart[0],longpart[1],longpart[2],longdir);
console.log(long);
marker = new google.maps.Marker({position: new google.maps.LatLng( lat,long),map: map});
var laLatLng = new google.maps.LatLng( lat, long);
map.panTo(laLatLng);
function start() {
document.getElementById("temp").innerHTML = "Waiting for data...";
document.getElementById("tstamp").innerHTML ="";
var deviceID = "4f004";
var accessToken = "1fa3342";
var varName = "lonlat";
requestURL = "https://api.spark.io/v1/devices/" + deviceID + "/" + varName + "/?access_token=" + accessToken;
$.getJSON(requestURL, function(json) {
document.getElementById("temp").innerHTML = "Current GPS Location -> " + json.result;
jstr = json.result;
// document.getElementById("temp").style.fontSize = "28px";
document.getElementById("tstamp").innerHTML = "Date/Time -> " + json.coreInfo.last_heard;
console.log(jstr);
console.log('calling DOH');
doh(jstr);
</script>
<script src="http://ajax.googleapis.com/ajax/libs/jquery/1.3.2/jquery.min.js" type="text/javascript" charset="utf-8"> </script>
<script src="https://maps.googleapis.com/maps/api/js?key=<<Your Google API Key Here>>&callback=initMap"
async defer></script>
</body>
</html>
