Hi @kennethlimcp thanks your reply, Nodeclipse is a Node IDE from eclipse which can debug, hightlight the code etc, for i am establishing the local cloud dev env. So , the web IDE you all provided will not be used right ? could you give me some suggestion for that ?
Tea pot Mode dispear after my upgrating the nodeclipse, The following message come out on the eclipse console without error. BUT,, the runing thread of node has been killed by some reason, spark - command could not be entered to the eclipse console now ....
@kennethlimcp, which Git branch i should use ? i used ‘master’, and i tried to start by command line method ,also the same problem , the nodejs runing thread has been stopped without errors.
Looks like you're running the CLI from source inside a debugger. Make sure your IDE knows to separate the arguments to the Node.js runtime, from the arguments provided to the CLI, usually there are separate fields for these.
