Hi !
I’ve juste had my first Spark Photon and I want to connecte with a IOS application. I take this exemple : https://github.com/spark/spark-sdk-ios
but it doesn’t work …
there is the link error:
ld: library not found for -lAFNetworking
clang: error: linker command failed with exit code 1 (use -v to see invocation)
I don’t understand…I hope someone have an idea …?
Thank you :)))
