Claim a photon : device-id response meaning for field "c":"1"
I was dreaming or read somewhere that the c field in the response of a GET device-id while setting up a photon means that the device is claimed already (if equal to 1)?
Example:
$ curl http://192.168.0.1/device-id
{"id":"3B0021001747353236343033","c":"1"}
Or maybe it does not have that meaning, may any of you know?
Pinging @rickkas7 in case you know this bit…
thanks!
references:
Manual photon claiming
It is true. Sort of.
The “c” parameter indicates whether the device claimed flag in the DCT (configuration flash) is set. This flag is cleared on a factory new device and set when you first claim a device.
The caveat is that when you unclaim a device using the CLI (or Cloud API), the device is unclaimed from the cloud device database, however the device is not notified and the DCT flag will still be set.
