Is it possible to program for example a pin to go high for 20 sec and then change that time with a nextion screen?
So, if I had a relay driving a motor that was controlled by a pin on a photon. And I programed the photon to send the pin high and therefore turn the motor on when a button was pushed on the nextion screen.
Can I also program a slider that goes from 5 sec to 30 sec and get the photon to reference the slider value on the screen, so it knows how long I want to set the pin high for.
