I suddenly recieve an error when building my software.
I saw a change has been made in the core-communication-lib, this might be the reason.
…/src/spark_utilities.cpp: In function ‘void Spark_Protocol_Init()’:
…/src/spark_utilities.cpp:458:22: error: invalid conversion from ‘unsigned int ()()’ to 'long unsigned int ()()’ [-fpermissive]
callbacks.millis = millis;
make: *** [obj/src/spark_utilities.o] Error 1
Can you please check if this change is the reason for the fault.
EDIT: Is it possible to base line the core-communication-lib and core-common-lib in the same way as you have done for the core-firmware. So we can developed against a stable release while you can continue your development on the latest.
Henk
