Hello,
I’m using a Boron to transmit data to a google sheet using a webhook. The boron regularly transmits strings of data to the particle cloud, and triggers a webhook to post the data to a google sheet.
Each package of data sent includes its own timestamp. But they are posted to the google sheet in the incorrect order. While running the test, I see that the cell signal was pretty low, around 20%. I’m suspecting the poor cell signal might be the cause, but does anyone else have an idea of what the problem could be?
The readings should be in the order:
4/18/2023 12:35:24 Sensor Start
4/18/2023 12:35:10 22.746 7.969 918.2 285
4/18/2023 12:35:12 Sensor Stop
But instead I’m seeing this, the timestamps are in the wrong order.
4/18/2023 12:35:21 22.759 7.974 917.8 285
4/18/2023 12:35:23 Sensor Stop
4/18/2023 12:35:31 22.768 7.974 916.4 285
4/18/2023 12:35:33 Sensor Stop
4/18/2023 12:35:35 Sensor Start
4/18/2023 12:35:42 22.777 7.973 917.8 285
4/18/2023 12:36:07 Sensor Start
4/18/2023 12:35:53 22.781 7.974 917.1 285
4/18/2023 12:35:55 Sensor Stop
4/18/2023 12:36:04 22.788 7.974 917.6 286
4/18/2023 12:35:57 Sensor Start
4/18/2023 12:36:15 22.793 7.976 917.6 286
4/18/2023 12:36:17 Sensor Stop
4/18/2023 12:36:18 Sensor Start
4/18/2023 12:35:46 Sensor Start
4/18/2023 12:36:06 Sensor Stop
4/18/2023 12:35:44 Sensor Stop
4/18/2023 12:36:25 22.796 7.976 917.3 286
