I can’t seem to flash firmware using a local server anymore. Everything works over the cloud, but when flashing locally I get a magenta flash for longer than usual, then breathing cyan, but the old code is still running.
This seems to be a new issue. I’ve never had a problem flashing locally before. I tried building the software to an older firmware version (0.4.7), but no luck.
