Hi, my first post. I have had several spark cores sitting for a while. I finally have those precious days to experiment and inspired by my recently installed Solar Voltaic setup decided to upgrade an arduino/wifly energy monitor with a spark. Basic setup was so easy but getting internet connectivity to work the way I wanted has proved to be more of a challenge.
I can’t reliably reflash the devices from the web IDE. It does not appear to be a simple connectivity issue as Spark.variable, function, publish and UDP read and write all appear to work reliably. I see some similar problems on the community but none which seem so invasive.
I have versions of code which used Spark.publish or broadcast local UDP packets with the same effect. I can no longer reflash the device from the web IDE while the connections are active. I structured the code to ensure that the main loop is short (around 200ms). A work around for the UDP version is to define a Spark.function which stops the UDP activity which I can call before flashing the code.
I have the same problem with a slave device which responds to the published event in one version or performs a UDP read in another. As it’s small I have included the code for the UDP version below.
Remote code update is a major reason for using the spark so I can experiment with devices in place. Am I missing something in the code to make the reflash reliable or might this be a local network configuration problem?
#include "SparkIntervalTimer/SparkIntervalTimer.h"
* skeleton receiver for a UDP packet
UDP udp;
int noPacketCount;
bool tFlag;
IntervalTimer sTimer1; // timer to trigger looking for a UDP packet
void udpRcv( void )
tFlag = true;
RGB.control(true);
udp.begin(50001);
noPacketCount = 0;
tFlag = false;
sTimer1.begin(udpRcv, 200, hmSec); // 100ms between udp receives
char rBuff[16];
int balance;
if (tFlag){
tFlag = false;
if (udp.parsePacket() > 0) {
noPacketCount = 0;
udp.read(rBuff, 16);
balance = String(rBuff).toInt();
if (balance>0) {
RGB.color(balance/4,0,0);
} else {
RGB.color(0, -balance/4, 0);
} else {
noPacketCount = min(100, noPacketCount+1);
if (noPacketCount > 5) {
RGB.color(0, 0, 255); // failed to find UDP packets
