What are the canbus pins on P1 and is this working like it work on the photon? I’m looking to switch to p1 for my production of devices but I need canbus.
I looked at the header file and found the answer is yes
On the P1
D1 = PB6 = CAN bus TX
D2 = PB5 = CANbus RX
Not only findable in header files but also in the docs
https://docs.particle.io/datasheets/p1-datasheet/#pin-out-diagrams
