# Can not Connect to my cell phone Hotspot
**URL:** <https://community.particle.io/t/can-not-connect-to-my-cell-phone-hotspot/21877>\
**Created:** [April 7, 2016, 4:42pm UTC](https://community.particle.io/t/can-not-connect-to-my-cell-phone-hotspot/21877 "2016-04-07T16:42:06Z")\
**Showing post:** 18
**Post date:** [April 9, 2016, 7:02am UTC](https://community.particle.io/t/can-not-connect-to-my-cell-phone-hotspot/21877/18 "2016-04-09T07:02:43Z")
> [@shiv](#):
> What does "ready" actually mean
This means that the WiFi module received the IP address, but if you request that IP via `WiFi.localIP()` it might not have been forwarded to the µC memory and hence you see 0.0.0.0.
To get around this add one call to `Particle.process()` - which would allow for pending WiFi tasks to be executed - before requesting IP or SSID.
Maybe like this
```cpp
SYSTEM_MODE(SEMI_AUTOMATIC)
void setup()
  WiFi.connect();
  Serial.begin(115200);
  while(Serial.read() < 0 && millis() < 10000) Particle.process(); // this waits here till you connect via Serial and hit a key (or max 10sec)
  if (!waitFor(WiFi.ready, 10000))
    Serial.println("Not able to connect to WiFi for 10sec");
  else
    Particle.process();
    Serial.printlnf("Here we go\nSSID\t: %s", WiFi.SSID());
    Particle.process();
    Serial.printlnf("localIP\t: %s", WiFi.localIP().toString().c_str());
void loop()
  int c = Serial.read();
  switch (c)
    case -1:
      // nothing to read, so ignore
      break;
    case '\r': // hit emter to connect
      Serial.println("Try to connect to cloud");
      Particle.connect();
      Serial.println("See cyan blinking?");
    default:
      Serial.write(c); // echo what we got
What color sequences do you see on the RGB LED?
Maybe post a video, since each step of the connection process has its own blink pattern, this gives you a good clue where the device is and which parts may be problematic (e.g. taking ages, timing out).
_[View the full topic](https://community.particle.io/t/can-not-connect-to-my-cell-phone-hotspot/21877)._
