Can my spark data be output to an XML file (and updated every minute) like the link below? I prefer to work with PHP and SimpleXML for a web project that I have in mind.
Although most of the API responses come in JSON, you can easily transform those into XML if you want. Here’s a PHP example for converting between the two (maybe not exactly what you meant, but it could help).
