Hi All!
I must admit, I’m a little stumped. I’m trying to set up an IFTTT recipe to trigger a servo on a “button” push, but it only seems to work every second “button” push.
I’ve attached the recipe in case I’m doing something wrong in there.
I’m sure there’s something wrong in the code, but it’s driving me mad. Can you help?
Cheers
Tim
// ** NOTES
// ** posStatus1 -> Reed switch for openServo -> HIGH=DISENGAGED, LOW=ENGAGED
// ** posStatus2 -> Reed switch for twistServo -> HIGH=DISENGAGED, LOW=ENGAGED
// ** openServo -> Operates string that moves blinds apart -> HIGH=CLOSED
// ** twistServo -> Operates beaded cord that turns blinds -> HIGH=FLUSH
#define TWIST_TIME 2000
int servoPin2 = D1; // ToggleTwist servo
Servo twistServo;
int buttonPin1 = D2; // ToggleTwist servo
int posDetector2 = D3; // ToggleTwist switch input
int led1 = D7; //indicator
int servoPos = 90; // Reset servo position
int posStatus2 = 0; // Position status variable ToggleTwist
volatile bool doTwist1 = false;
volatile bool doTwist2 = false;
pinMode(buttonPin1, INPUT_PULLUP);
pinMode(led1, OUTPUT);
twistServo.write(90);
twistServo.attach( servoPin2 ); // Attach Twist servo to D1
Particle.function("toggleTwist", toggleTwist);
Particle.function("commandTwist", commandTwist);
pinMode(posDetector2, INPUT_PULLUP); // Check status of ToggleTwist switch
Particle.variable("posStatus2", posStatus2); // Declare status variable to check ToggleTwist position status
digitalWrite(led1, LOW);
void loop () {
bool buttonState = !digitalRead(buttonPin1);
if (doTwist1 == true || buttonState == HIGH) { // ToggleTwist blinds open/closed
posStatus2 = digitalRead(posDetector2); // Status of ToggleTwist switch
if (posStatus2 == LOW) {
// If FLUSH TO WINDOW
digitalWrite(led1,HIGH);
twistServo.write( 100 );
delay(TWIST_TIME);
twistServo.write( 90 );
digitalWrite(led1,LOW);
delay(1000);
delay(TWIST_TIME);
doTwist1 = false;
else {
doTwist1 = false;
else if (doTwist2 == true) { // ToggleTwist blinds open/closed
if (posStatus2 == HIGH) {
twistServo.write( 80 );
delay(TWIST_TIME);
delay(500);
delay(500);
delay(500);
delay(500);
delay(TWIST_TIME);
doTwist2 = false;
else {
doTwist2 = false;
else {
int toggleTwist(String command) {
doTwist1 = true;
else {
doTwist2 = true;
int commandTwist(String command) {
doTwist1 = true;
else {
doTwist2 = true;
