Building with firmware: can not select the item
when i use web build. i flash my core failed .
and i thought maybe the version problem.
but i can’t select the version.
please help me . thanks
For some reason, your Core is appearing under “Other”. Please send me the device ID and I’ll get that fixed for you
54ff6f066678574919490867 it is my device ID. thanks
For the record, I’ve got two cores that are showing up as “other”, as well. But I haven’t had any trouble flashing them OTA.
yes. it works now.
i change my routing device. and cross the great wall of china.
thanks
