Here is my Christmas list for Build:
- Ability to fork/clone my own work. It is frustrating managing (or not) code on Build.
- Ability to print my code.
- Integration with github.
Fully agreeing with the fact that the Web IDE deserves a (major) overhaul, have you considered using Particle Dev? It’s based on atom and should allow you to do a lot more customization, as well as the things you’ve mentioned here. Might be worthwhile looking into
@Moors7: I have not spent the time to learn that yet. Mainly because I started in build and there is not a way to open build code in dev (at least as far as I know). Plus – you still cannot print in dev (afaik).
In dev you have the files locally, so you can open them with any program to print like programmers notepad.
