# Broken embedded spark.io images in older forum posts
**URL:** <https://community.particle.io/t/broken-embedded-spark-io-images-in-older-forum-posts/20091>\
**Category:** General\
**Created:** [February 15, 2016, 8:43pm UTC](https://community.particle.io/t/broken-embedded-spark-io-images-in-older-forum-posts/20091 "2016-02-15T20:43:41Z")\
**Showing post:** 3
**Author:** ![rickkas7](https://sea2.discourse-cdn.com/flex026/user_avatar/community.particle.io/rickkas7/32/8681_2.png) [@rickkas7](https://community.particle.io/u/rickkas7)\
**Post date:** [February 16, 2016, 3:23pm UTC](https://community.particle.io/t/broken-embedded-spark-io-images-in-older-forum-posts/20091/3 "2016-02-16T15:23:09Z")
As a workaround, if you modify the URL to change the [spark.io](http://spark.io) to [particle.io](http://particle.io) it works, even with older posts (like the beehive one you posted).
[Beehive Monitor (UDP, Sleep, Thermistor, WiFi antenna, ADC speed, RAM)](https://community.particle.io/t/beehive-monitor-udp-sleep-thermistor-wifi-antenna-adc-speed-ram/4524)
_[View the full topic](https://community.particle.io/t/broken-embedded-spark-io-images-in-older-forum-posts/20091)._
