# Boron Pending Firmware Updates only applied after power off/on
**URL:** <https://community.particle.io/t/boron-pending-firmware-updates-only-applied-after-power-off-on/48687>\
**Tags:** boron\
**Created:** [March 26, 2019, 2:49am UTC](https://community.particle.io/t/boron-pending-firmware-updates-only-applied-after-power-off-on/48687 "2019-03-26T02:49:08Z")\
**Showing post:** 2
**Post date:** [March 26, 2019, 4:57am UTC](https://community.particle.io/t/boron-pending-firmware-updates-only-applied-after-power-off-on/48687/2 "2019-03-26T04:57:02Z")
In order to get the cloud to inform your device about pending updates you (currently) need a full hanshake.
Have a read here
> [@How to force a handshake for OTA updates](https://community.particle.io/t/how-to-force-a-handshake-for-ota-updates/36836):
> Hi, I have 50 devices in the field and from time to time I need them to do OTA updates. However, often times I have noticed that it doesn’t work even though on the particle cloud, the device is locked to a new firmware version. Why is this? What I’ve noticed, if I do a hard reset of devices, it handshakes with the cloud. If a handshake occurs, then it will do the OTA update just fine. What if I want one handshake to happen every night at 8pm to basically check and allow for OTA updates. How ca…
_[View the full topic](https://community.particle.io/t/boron-pending-firmware-updates-only-applied-after-power-off-on/48687)._
