Boron Low ADC Readings
boron
Tags: #<Tag:0x00007fe2224f2188>
#1
In my current project, I am noticing ADC values that are unexpectedly low. When 3.3V is applied to the A2 pin, one Boron I have reads it as 4027 and the other reads it as 4000. I dumbed down the entire project and connected the D2 pin to the A2 pin. When I set the D2 pin as HIGH and read it through the A2 pin, the ADC averages around 4000. A multimeter shows it at 3.3V so I am puzzled. Here is my code:
  Serial.begin(115200); //open serial console
  delay(10000); //10 seconds
  pinMode(D2, OUTPUT);
  pinMode(A2, INPUT_PULLDOWN);
  int adc_value = 0;
  digitalWrite(D2, HIGH);
  delay(2000);
  adc_value = analogRead(A2);
  Log.info("ADC: %d", adc_value);
  delay(5000);
#2
Try removing the pinMode(A2, INPUT_PULLDOWN) line.
When you attach an internal pull-down resistor you shouldn’t be surprised to sense a pulled-down value :wink:
#3
Good point. I removed it and now the values are around 4030 for 3.3V applied to A2.
#4
What do you read when directly reading 3v3?
#5
So just so I understand, I have a wire directly from the 3v3 pin to A2, it reads around 4030.
#6
Exactly. This should be the only connection to A2. The device should not even sit in a breadboard or some antistatic sponge or anything else.
Additionally, how are you powering the device (battery only, USB + battery, USB only)?
#7
Yup that’s how I have it. No breadboard. I was only powering it with USB. Let me add a Lipo that is charged and then test it.
#8
I’ve tried both USB and USB+LiPo and get 4095 in all cases with this code
SerialLogHandler serLog(LOG_LEVEL_WARN, {{"app", LOG_LEVEL_INFO}});
  int adc_value = 0;
  delay(2000);
  delay(5000);
#9
so I have plugged in a LiPO and USB and it is still reading around 4030. I swapped out and tried another Boron and now get values around 4060?
0000051476 [app] INFO: ADC: 4070
0000058478 [app] INFO: ADC: 4060
0000065479 [app] INFO: ADC: 4062
0000072481 [app] INFO: ADC: 4062
0000079481 [app] INFO: ADC: 4057
0000086483 [app] INFO: ADC: 4060
0000093484 [app] INFO: ADC: 4057
0000100485 [app] INFO: ADC: 4061
0000107487 [app] INFO: ADC: 4059
0000114488 [app] INFO: ADC: 4058
0000121490 [app] INFO: ADC: 4060
0000128491 [app] INFO: ADC: 4057
0000135492 [app] INFO: ADC: 4062
Do I need to make some sort of adjustment to factor for this difference? The voltage coming into the pin is still 3.3V.
#10
That shouldn’t be required.
Have you tested with my code? I can’t make any of my Gen3 devices report anything but 4095 (occasionally 4094) with that code and a D2-A2 bridge :confused:
#11
Yep I am using your code. I have 3 Borons doing the same thing. BUT I tested the same setup and code on an Argon and it works fine, 4095. Its hard for me to believe I have 3 bad Borons?
#12
That is rather peculiar - maybe @marekparticle can take this one from here.
BTW, can you post a photo of your Boron setup?
#13
Here is a picture of the setup. The USB cable is going to my MacBook Pro.
#14
I see you have no antenna attached - if you have the cell module on you should not do that. These modules are not meant to be running without load on the output stage.
#15
I actually did not know that. I do have SYSTEM_MODE(SEMI_AUTOMATIC); at the top of my code. Does this change things?
#16
When the radio is not on (as in SEMI_AUTOMATIC) it shouldn’t matter.
#17
I’m seeing similar results with a Boron LTE that was shipped recently.
All tests with Cellular Antenna Connected, USB powered, and Li-Po connected.
// Using 3V3 Pin Bridge
0000013954 [app] INFO: ADC: 4079
0000018955 [app] INFO: ADC: 4075
0000023955 [app] INFO: ADC: 4081
0000028956 [app] INFO: ADC: 4082
0000033957 [app] INFO: ADC: 4078
0000038957 [app] INFO: ADC: 4085
0000043958 [app] INFO: ADC: 4083
0000048958 [app] INFO: ADC: 4081
0000053959 [app] INFO: ADC: 4079
0000058959 [app] INFO: ADC: 4079
0000063960 [app] INFO: ADC: 4081
0000068961 [app] INFO: ADC: 4078
// Using D2 Pin Bridge
0000035008 [app] INFO: ADC: 4081
0000040009 [app] INFO: ADC: 4088
0000045009 [app] INFO: ADC: 4079
0000050010 [app] INFO: ADC: 4082
0000055010 [app] INFO: ADC: 4074
0000060011 [app] INFO: ADC: 4071
0000065012 [app] INFO: ADC: 4087
0000070012 [app] INFO: ADC: 4085
0000075013 [app] INFO: ADC: 4079
0000080013 [app] INFO: ADC: 4081
0000085014 [app] INFO: ADC: 4076
#18
Huh? :flushed:
That’s something @marekparticle and @oddwires1 may want to chime in on - that seems rather wrong to me.
#19
Hi @Particle9 - sorry to be getting to you so late, had a break for the holiday weekend (thanks for the ping, @ScruffR). I can’t reproduce this on my own device, so it looks like something must be up hardware-wise. Would you mind creating a support ticket (support.particle.io) and we can determine whether or not a replacement is in order?
#20
@marekparticle, I’m reproducing this with “replacement” Boron’s that were recently shipped to me.
Note: This ADC error isn’t a concern for me personally, but I wanted you to be aware.
Do you have a Boron from a recent production run to try ?
I switched to A3 Pin, and disconnected the Li-Po during the test, no significant change:
// A3 to 3V3 Pin Bridge
0000014060 [app] INFO: ADC: 4088
0000019060 [app] INFO: ADC: 4079
0000024061 [app] INFO: ADC: 4088
0000029062 [app] INFO: ADC: 4079
0000034062 [app] INFO: ADC: 4077
// Disconnected the Li-Po, Boron was Re-Charging previously
0000039063 [app] INFO: ADC: 4075
0000044063 [app] INFO: ADC: 4078
0000049064 [app] INFO: ADC: 4088
0000054065 [app] INFO: ADC: 4082
0000059065 [app] INFO: ADC: 4074
