Boron gets stuck connecting? (CoAP CON 0.00 size=4 token= id=2058)
OS 5.3.1
My boron got completely stuck going online.
The program went happily to sleep
(config here)
config.mode(SystemSleepMode::ULTRA_LOW_POWER).duration(customSleepMillis).gpio(WKP, FALLING).gpio(DIO_PIN, FALLING).gpio(DIO2_PIN, FALLING).flag(SystemSleepFlag::WAIT_CLOUD);
and then woke up, when it attempted to go back online it started spamming this over and over again for the last 30 minutes:
0082248SYSTEM: got event 64 with value 0
tocol.handshake] INFO: Skipping HELLO message
0082248155 [comm.coap] TRACE: Sending CoAP message
0082248156 [comm.coap] TRACE: CON 0.00  size=4 token= id=2058
Fortunately it was on my test bench in trace logging mode.
below is the whole log (i cut the 30 minutes of spewing the garbage) along with AT commands.
besides implementing the hardware watchdog is there anything I should do with this?
 ==== LOOP ====
loop start. freemem=58064
0082170875 [app] INFO: System time: Mon May  8 23:35:51 2023
0082170878 [app] INFO: SoC=86.06
0082170878 [app] INFO: Cellular = 0.  Cloud = 0.
0082170879 [app] INFO: getting state of charge
0082170882 [app] INFO: SoC fuelGauge= 86.06
0082170883 [app] INFO: vCell= 4.07
0082171883 [app] INFO: *********** Upload state
0082171883 [app] INFO: am I stuck in a world that doesn't appreciate me?
0082171883 [app] INFO: current queued publishing numEvents=26
0082171884 [app] INFO: upload state, currently no connection, will go online
0082171884 [app] INFO: Cell On
0082171885 [system.nm] TRACE: Request to power on the interface
0082171886 [ncp.client] TRACE: Powering modem on, ncpId: 0x44
0082171886 [net.pppncp] TRACE: NCP event 3
0082171887 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0082171888 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
0082171889 [system.nm] INFOSYSTEM: got event 32 with value 0
: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
0082171891 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
0082172037 [net.pppncp] TRACE: NCP event 3
0082172038 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0082172038 [system.nm] TRACE: Interface 4 power state changed: 2
0082172039 [ncp.client] TRACE: Modem powered on
0082172039 [ncp.client] TRACE: Setting UART voltage translator state 1
0082172139 [ncp.client] TRACE: Setting UART voltage translator state 0
0082172239 [ncp.client] TRACE: Setting UART voltage translator state 1
0082173240 [ncp.at] TRACE: > AT
0082174240 [ncp.at] TRACE: > AT
0082175240 [ncp.at] TRACE: > AT
0082176240 [ncp.at] TRACE: > AT
0082176262 [ncp.at] TRACE: < OK
0082176263 [ncp.client] TRACE: NCP ready to accept AT commands
0082176263 [ncp.at] TRACE: > AT
0082176264 [ncp.at] TRACE: < OK
0082176264 [ncp.at] TRACE: > ATI9
0082176266 [ncp.at] TRACE: < L0.0.00.00.05.08,A.02.04
0082176267 [ncp.at] TRACE: < OK
0082176267 [ncp.client] TRACE: App firmware: 204
0082176267 [ncp.at] TRACE: > AT+UGPIOC?
0082176269 [ncp.at] TRACE: < +UGPIOC:
0082176270 [ncp.at] TRACE: < 7,255
0082176270 [ncp.at] TRACE: < 16,255
0082176271 [ncp.at] TRACE: < 19,255
0082176271 [ncp.at] TRACE: < 23,0
0082176271 [ncp.at] TRACE: < 24,255
0082176272 [ncp.at] TRACE: < 25,255
0082176272 [ncp.at] TRACE: < 42,255
0082176273 [ncp.at] TRACE: < OK
0082176273 [ncp.at] TRACE: > AT+UGPIOR=23
0082176276 [ncp.at] TRACE: < +UGPIOR: 23,1
0082176276 [ncp.at] TRACE: < OK
0082176276 [ncp.client] INFO: Using internal SIM card
0082176277 [ncp.at] TRACE: > AT+CPIN?
0082176279 [ncp.at] TRACE: < +CME ERROR: SIM not inserted
0082177279 [ncp.at] TRACE: > AT+CPIN?
0082181126 [ncp.at] TRACE: < +CPIN: READY
0082181126 [ncp.at] TRACE: < OK
0082181126 [ncp.at] TRACE: > AT+CCID
0082181129 [ncp.at] TRACE: < +CCID: 89014103272806309015
0082181129 [ncp.at] TRACE: < OK
0082181130 [ncp.at] TRACE: > AT+IFC?
0082181132 [ncp.at] TRACE: < +IFC: 2,2
0082181132 [ncp.at] TRACE: < OK
0082181132 [ncp.at] TRACE: > AT+CFUN=0,0
0082182898 [ncp.at] TRACE: < OK
0082182899 [ncp.at] TRACE: > AT+CFUN=1,0
0082182901 [ncp.at] TRACE: < OK
0082182902 [ncp.at] TRACE: > AT+CPIN?
0082182903 [ncp.at] TRACE: < +CPIN: READY
0082182904 [ncp.at] TRACE: < OK
0082182904 [ncp.at] TRACE: > AT+CCID
0082182906 [ncp.at] TRACE: < +CCID: 89014103272806309015
0082182906 [ncp.at] TRACE: < OK
0082182906 [ncp.at] TRACE: > AT+IFC?
0082182908 [ncp.at] TRACE: < +IFC: 2,2
0082182908 [ncp.at] TRACE: < OK
0082182908 [ncp.at] TRACE: > AT+IFC=2,2
0082182911 [ncp.at] TRACE: < OK
0082182911 [ncp.at] TRACE: > AT
0082182912 [ncp.at] TRACE: < OK
0082182913 [ncp.at] TRACE: > AT+IPR=460800
0082182919 [ncp.at] TRACE: < OK
0082183919 [ncp.at] TRACE: > AT
0082183922 [ncp.at] TRACE: < OK
0082183922 [ncp.at] TRACE: > AT+CCID
0082183925 [ncp.at] TRACE: < +CCID: 89014103272806309015
0082183925 [ncp.at] TRACE: < OK
0082183926 [ncp.at] TRACE: > AT+CIMI
0082183929 [ncp.at] TRACE: < 310410280630901
0082183929 [ncp.at] TRACE: < OK
0082183929 [ncp.at] TRACE: > AT+UMNOPROF?
0082183932 [ncp.at] TRACE: < +UMNOPROF: 2
0082183933 [ncp.at] TRACE: < OK
0082183933 [ncp.at] TRACE: > AT+COPS=3,2
0082183937 [ncp.at] TRACE: < OK
0082183937 [ncp.at] TRACE: > AT+CGEREP=1,0
0082183939 [ncp.at] TRACE: < OK
0082183940 [ncp.at] TRACE: > AT+URAT?
0082183943 [ncp.at] TRACE: < +CME ERROR: Operation not supported
0082183944 [ncp.at] TRACE: > AT+CPSMS?
0082183948 [ncp.at] TRACE: < +CPSMS:0,,,"10000101","00000011"
0082183949 [ncp.at] TRACE: < OK
0082183949 [ncp.at] TRACE: > AT+CEDRXS?
0082183952 [ncp.at] TRACE: < +CEDRXS:
0082183952 [ncp.at] TRACE: < OK
0082183953 [ncp.at] TRACE: > AT+CMUX=0,0,,1509,,,,,
0082183958 [ncp.at] TRACE: < OK
0082183958 [mux] INFO: Starting GSM07.10 muxer
0082183959 [mux] INFO: GSM07.10 muxer thread started
0082183959 [mux] INFO: Openning mux channel 0
0082185227 [mux] INFO: Openning mux channel 1
0082185231 [ncp.at] TRACE: > AT
0082185231 [ncp.at] TRACE: < +CGEV: ME DETACH
0082185235 [ncp.at] TRACE: < OK
0082185235 [ncp.client] TRACE: NCP state changed: 1
0082185235 [net.pppncp] TRACE: NCP event 1
0082185236 [net.ppp.client] TRACE: PPP thread event ADM_UP data=0
0082185237 [net.ppp.client] TRACE: State NONE -> READY
0082185240 [ncp.at] TRACE: > AT
0082185245 [ncp.at] TRACE: < OK
0082185245 [ncp.at] TRACE: > AT+CFUN?
0082185250 [ncp.at] TRACE: < +CFUN: 1
0082185251 [ncp.at] TRACE: < OK
0082185251 [ncp.at] TRACE: > AT+CCID
0082185257 [ncp.at] TRACE: < +CCID: 89014103272806309015
0082185257 [ncp.at] TRACE: < OK
0082185258 [ncp.at] TRACE: > AT+CIMI
0082185263 [ncp.at] TRACE: < 310410280630901
0082185263 [ncp.at] TRACE: < OK
0082185264 [ncp.at] TRACE: > AT+CGDCONT?
0082185271 [ncp.at] TRACE: < +CGDCONT: 1,"IP","10569.mcs","10.210.71.77",0,0,0,0
0082185272 [ncp.at] TRACE: < OK
0082185273 [ncp.at] TRACE: > AT+CFUN?
0082185278 [ncp.at] TRACE: < +CFUN: 1
0082185278 [ncp.at] TRACE: < OK
0082185279 [ncp.at] TRACE: > AT+CEREG=2
0082185282 [ncp.at] TRACE: < OK
0082185283 [ncp.client] TRACE: NCP connection state changed: 1
0082185283 [net.pppncp] TRACE: NCP event 2
0082185283 [net.pppncp] TRACE: State changed event: 1
0082185284 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0082185285 [ncp.at] TRACE: > AT+COPS?
0082185290 [ncp.at] TRACE: < +COPS: 0,2,"310410",7
0082185291 [ncp.at] TRACE: < OK
0082185291 [ncp.at] TRACE: > AT+CEREG?
0082185296 [ncp.at] TRACE: < +CEREG: 2,1,"900E","509F810",7
0082185297 [ncp.at] TRACE: < OK
0082185297 [ncp.client] TRACE: NCP connection state changed: 2
0082185298 [mux] INFO: Openning mux channel 2
0082186564 [net.pppncp] TRACE: NCP event 100
0082186564 [net.pppncp] TRACE: New auth info
0082186567 [net.pppncp] TRACE: NCP event 2
0082186567 [net.pppncp] TRACE: State changed event: 2
0082186568 [net.ppp.client] TRACE: PPP thread event LOWER_UP data=0
0082186569 [net.ppp.client] TRACE: State READY -> CONNECT
0082186569 [net.ppp.client] TRACE: State CONNECT -> CONNECTING
0082186569 [ncp.at] TRACE: > AT+CIMI
0082186573 [ncp.at] TRACE: < 310410280630901
0082186573 [ncp.at] TRACE: < OK
0082186574 [ncp.at] TRACE: > AT
0082186579 [ncp.at] TRACE: < OK
0082186580 [ncp.at] TRACE: > AT+CGATT?
0082186584 [ncp.at] TRACE: < +CGATT: 1
0082186585 [ncp.at] TRACE: < OK
0082187586 [ncp.at] TRACE: > AT
0082188587 [ncp.at] TRACE: > AT
0082189588 [ncp.at] TRACE: > AT
0082190589 [ncp.at] TRACE: > AT
0082191590 [ncp.at] TRACE: > AT
0082192590 [ncp.client] ERROR: Failed to enter data mode
0082192590 [net.ppp.client] ERROR: Failed to dial
0082192591 [net.pppncp] TRACE: NCP event 3
0082192591 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0082192592 [system.nm] TRACE: Interface 4 power state changed: 3
0082192593 [ncp.client] TRACE: Try powering modem off using AT command
0082192594 [ncp.at] TRACE: > AT+CPWROFF
0082192592 [net.ppp.client] TRACE: State CONNECTING -> CONNECT
0082192604 [ncp.at] TRACE: < OK
0082192605 [ncp.client] TRACE: Waiting the modem to be turned off...
0082192694 [net.ppp.client] TRACE: State CONNECT -> CONNECTING
0082192916 [net.pppncp] TRACE: NCP event 3
0082192916 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0082192917 [system.nm] TRACE: Interface 4 power state changed: 1
0082192918 [ncp.client] TRACE: It takes 313 ms to power off the modem.
0082192918 [mux] INFO: Stopping GSM07.10 muxer
0082192918 [mux] INFO: Gracefully stopping GSM07.10 muxer
0082192919 [mux] INFO: Closing all muxed channels
0082192919 [mux] INFO: Closing mux channel 1
0082192920 [mux] INFO: Closing mux channel 2
0082192920 [mux] INFO: Muxed channel 3 already closed
0082192921 [mux] INFO: Muxed channel 4 already closed
0082192921 [mux] INFO: GSM07.10 muxer thread exiting
0082192921 [ncp.client] TRACE: NCP connection state changed: 1
0082192922 [net.pppncp] TRACE: NCP event 2
0082192923 [net.pppncp] TRACE: State changed event: 1
0082192923 [mux] INFO: GSM07.10 muxer stopped
0082192924 [ncp.client] TRACE: Setting UART voltage translator state 0
0082192924 [ncp.client] TRACE: Soft power off modem successfully
0082192924 [ncp.client] TRACE: Deinit modem serial.
0082192925 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0082192926 [ncp.client] ERROR: Failed to enter data mode
0082192927 [net.ppp.client] ERROR: Failed to dial
0082192927 [net.ppp.client] TRACE: State CONNECTING -> CONNECT
0082192927 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0082192928 [net.ppp.client] TRACE: State CONNECT -> DISCONNECT
0082192929 [net.ppp.client] TRACE: State DISCONNECT -> DISCONNECTING
0082192929 [net.ppp.client] TRACE: PPP thread event ERROR data=5
0082192930 [net.pppncp] ERROR: PPP error event data=5
0082192930 [net.ppp.client] TRACE: PPP thread event DOWN data=0
0082192931 [net.ppp.client] TRACE: State DISCONNECTING -> DISCONNECTED
0082192931 [net.ppp.client] TRACE: State DISCONNECTED -> READY
0082193027 [ncp.client] TRACE: Modem already off
0082193027 [ncp.client] TRACE: Setting UART voltage translator state 0
0082193028 [ncp.client] TRACE: Soft power off modem successfully
0082193029 [ncp.client] TRACE: Deinit modem serial.
0082193029 [ncp.client] TRACE: NCP connection state changed: 0
0082193029 [net.pppncp] TRACE: NCP event 2
0082193030 [net.pppncp] TRACE: State changed event: 0
0082193030 [ncp.client] TRACE: NCP state changed: 0
0082193031 [net.pppncp] TRACE: NCP event 1
0082193031 [ncp.client] TRACE: Powering modem on, ncpId: 0x44
0082193032 [net.pppncp] TRACE: NCP event 3
0082193032 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0082193033 [system.nm] TRACE: Interface 4 power state changed: 4
0082193031 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0082193184 [net.pppncp] TRACE: NCP event 3
0082193184 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0082193185 [system.nm] TRACE: Interface 4 power state changed: 2
0082193185 [ncp.client] TRACE: Modem powered on
0082193186 [ncp.client] TRACE: Setting UART voltage translator state 1
0082193286 [ncp.client] TRACE: Setting UART voltage translator state 0
0082193386 [ncp.client] TRACE: Setting UART voltage translator state 1
0082194387 [ncp.at] TRACE: > AT
0082195387 [ncp.at] TRACE: > AT
0082196387 [ncp.at] TRACE: > AT
0082197387 [ncp.at] TRACE: > AT
0082197420 [ncp.at] TRACE: < OK
0082197420 [ncp.client] TRACE: NCP ready to accept AT commands
0082197421 [ncp.at] TRACE: > AT
0082197422 [ncp.at] TRACE: < OK
0082197423 [ncp.at] TRACE: > ATI9
0082197424 [ncp.at] TRACE: < L0.0.00.00.05.08,A.02.04
0082197425 [ncp.at] TRACE: < OK
0082197426 [ncp.client] TRACE: App firmware: 204
0082197426 [ncp.at] TRACE: > AT+UGPIOC?
0082197428 [ncp.at] TRACE: < +UGPIOC:
0082197429 [ncp.at] TRACE: < 7,255
0082197429 [ncp.at] TRACE: < 16,255
0082197430 [ncp.at] TRACE: < 19,255
0082197430 [ncp.at] TRACE: < 23,0
0082197430 [ncp.at] TRACE: < 24,255
0082197431 [ncp.at] TRACE: < 25,255
0082197431 [ncp.at] TRACE: < 42,255
0082197432 [ncp.at] TRACE: < OK
0082197432 [ncp.at] TRACE: > AT+UGPIOR=23
0082197435 [ncp.at] TRACE: < +UGPIOR: 23,1
0082197435 [ncp.at] TRACE: < OK
0082197435 [ncp.client] INFO: Using internal SIM card
0082197436 [ncp.at] TRACE: > AT+CPIN?
0082197438 [ncp.at] TRACE: < +CME ERROR: SIM not inserted
0082198438 [ncp.at] TRACE: > AT+CPIN?
0082202281 [ncp.at] TRACE: < +CPIN: READY
0082202281 [ncp.at] TRACE: < OK
0082202281 [ncp.at] TRACE: > AT+CCID
0082202284 [ncp.at] TRACE: < +CCID: 89014103272806309015
0082202284 [ncp.at] TRACE: < OK
0082202285 [ncp.at] TRACE: > AT+IFC?
0082202287 [ncp.at] TRACE: < +IFC: 2,2
0082202287 [ncp.at] TRACE: < OK
0082202288 [ncp.at] TRACE: > AT+CFUN=0,0
0082203268 [ncp.at] TRACE: < OK
0082203268 [ncp.at] TRACE: > AT+CFUN=1,0
0082203271 [ncp.at] TRACE: < OK
0082203272 [ncp.at] TRACE: > AT+CPIN?
0082203274 [ncp.at] TRACE: < +CPIN: READY
0082203275 [ncp.at] TRACE: < OK
0082203275 [ncp.at] TRACE: > AT+CCID
0082203279 [ncp.at] TRACE: < +CCID: 89014103272806309015
0082203279 [ncp.at] TRACE: < OK
0082203280 [ncp.at] TRACE: > AT+IFC?
0082203282 [ncp.at] TRACE: < +IFC: 2,2
0082203282 [ncp.at] TRACE: < OK
0082203283 [ncp.at] TRACE: > AT+IFC=2,2
0082203285 [ncp.at] TRACE: < OK
0082203286 [ncp.at] TRACE: > AT
0082203288 [ncp.at] TRACE: < OK
0082203289 [ncp.at] TRACE: > AT+IPR=460800
0082203297 [ncp.at] TRACE: < OK
0082204298 [ncp.at] TRACE: > AT
0082204301 [ncp.at] TRACE: < OK
0082204301 [ncp.at] TRACE: > AT+CCID
0082204304 [ncp.at] TRACE: < +CCID: 89014103272806309015
0082204305 [ncp.at] TRACE: < OK
0082204305 [ncp.at] TRACE: > AT+CIMI
0082204307 [ncp.at] TRACE: < 310410280630901
0082204307 [ncp.at] TRACE: < OK
0082204308 [ncp.at] TRACE: > AT+UMNOPROF?
0082204309 [ncp.at] TRACE: < +UMNOPROF: 2
0082204310 [ncp.at] TRACE: < OK
0082204310 [ncp.at] TRACE: > AT+COPS=3,2
0082204312 [ncp.at] TRACE: < OK
0082204312 [ncp.at] TRACE: > AT+CGEREP=1,0
0082204314 [ncp.at] TRACE: < OK
0082204314 [ncp.at] TRACE: > AT+URAT?
0082204318 [ncp.at] TRACE: < +CME ERROR: Operation not supported
0082204318 [ncp.at] TRACE: > AT+CPSMS?
0082204324 [ncp.at] TRACE: < +CPSMS:0,,,"10000101","00000011"
0082204325 [ncp.at] TRACE: < OK
0082204325 [ncp.at] TRACE: > AT+CEDRXS?
0082204330 [ncp.at] TRACE: < +CEDRXS:
0082204330 [ncp.at] TRACE: < OK
0082204330 [ncp.at] TRACE: > AT+CMUX=0,0,,1509,,,,,
0082204335 [ncp.at] TRACE: < OK
0082204335 [mux] INFO: Starting GSM07.10 muxer
0082204336 [mux] INFO: Openning mux channel 0
0082204337 [mux] INFO: GSM07.10 muxer thread started
0082204339 [mux] INFO: Openning mux channel 1
0082204342 [ncp.at] TRACE: > AT
0082204342 [ncp.at] TRACE: < +CEREG: 0
0082204343 [ncp.at] TRACE: < +CGEV: ME DETACH
0082204345 [ncp.at] TRACE: < OK
0082204345 [ncp.client] TRACE: NCP state changed: 1
0082204345 [net.pppncp] TRACE: NCP event 1
0082204346 [net.ppp.client] TRACE: PPP thread event ADM_UP data=0
0082204350 [ncp.at] TRACE: > AT
0082204355 [ncp.at] TRACE: < OK
0082204356 [ncp.at] TRACE: > AT+CFUN?
0082204359 [ncp.at] TRACE: < +CFUN: 1
0082204359 [ncp.at] TRACE: < OK
0082204360 [ncp.at] TRACE: > AT+CCID
0082204364 [ncp.at] TRACE: < +CCID: 89014103272806309015
0082204364 [ncp.at] TRACE: < OK
0082204365 [ncp.at] TRACE: > AT+CIMI
0082204368 [ncp.at] TRACE: < 310410280630901
0082204368 [ncp.at] TRACE: < OK
0082204369 [ncp.at] TRACE: > AT+CGDCONT?
0082204374 [ncp.at] TRACE: < +CGDCONT: 1,"IP","10569.mcs","10.210.71.77",0,0,0,0
0082204375 [ncp.at] TRACE: < OK
0082204376 [ncp.at] TRACE: > AT+CFUN?
0082204378 [ncp.at] TRACE: < +CFUN: 1
0082204379 [ncp.at] TRACE: < OK
0082204380 [ncp.at] TRACE: > AT+CEREG=2
0082204382 [ncp.at] TRACE: < OK
0082204382 [ncp.client] TRACE: NCP connection state changed: 1
0082204383 [net.pppncp] TRACE: NCP event 2
0082204383 [net.pppncp] TRACE: State changed event: 1
0082204384 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0082204385 [ncp.at] TRACE: > AT+COPS?
0082204387 [ncp.at] TRACE: < +COPS: 0,2,"310410",7
0082204388 [ncp.at] TRACE: < OK
0082204388 [ncp.at] TRACE: > AT+CEREG?
0082204392 [ncp.at] TRACE: < +CEREG: 2,1,"900E","509F810",7
0082204392 [ncp.at] TRACE: < OK
0082204393 [ncp.client] TRACE: NCP connection state changed: 2
0082204393 [mux] INFO: Openning mux channel 2
0082205659 [net.pppncp] TRACE: NCP event 100
0082205659 [net.pppncp] TRACE: New auth info
0082205662 [net.pppncp] TRACE: NCP event 2
0082205662 [net.pppncp] TRACE: State changed event: 2
0082205663 [net.ppp.client] TRACE: PPP thread event LOWER_UP data=0
0082205663 [net.ppp.client] TRACE: State READY -> CONNECT
0082205664 [ncp.at] TRACE: > AT+CIMI
0082205664 [net.ppp.client] TRACE: State CONNECT -> CONNECTING
0082205669 [ncp.at] TRACE: < 310410280630901
0082205670 [ncp.at] TRACE: < OK
0082205670 [ncp.at] TRACE: > AT
0082205675 [ncp.at] TRACE: < OK
0082205676 [ncp.at] TRACE: > AT+CGATT?
0082205681 [ncp.at] TRACE: < +CGATT: 1
0082205681 [ncp.at] TRACE: < OK
0082206682 [ncp.at] TRACE: > AT
0082207684 [ncp.at] TRACE: > AT
0082208685 [ncp.at] TRACE: > AT
0082209686 [ncp.at] TRACE: > AT
0082210687 [ncp.at] TRACE: > AT
0082211687 [ncp.client] ERROR: Failed to enter data mode
0082211687 [net.ppp.client] ERROR: Failed to dial
0082211688 [net.ppp.client] TRACE: State CONNECTING -> CONNECT
0082211688 [net.pppncp] TRACE: NCP event 3
0082211689 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0082211690 [system.nm] TRACE: Interface 4 power state changed: 3
0082211690 [ncp.client] TRACE: Try powering modem off using AT command
0082211691 [ncp.at] TRACE: > AT+CPWROFF
0082211702 [ncp.at] TRACE: < OK
0082211703 [ncp.client] TRACE: Waiting the modem to be turned off...
0082211788 [net.ppp.client] TRACE: State CONNECT -> CONNECTING
0082212033 [net.pppncp] TRACE: NCP event 3
0082212033 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0082212034 [system.nm] TRACE: Interface 4 power state changed: 1
0082212035 [ncp.client] TRACE: It takes 332 ms to power off the modem.
0082212035 [mux] INFO: Stopping GSM07.10 muxer
0082212035 [mux] INFO: Gracefully stopping GSM07.10 muxer
0082212036 [mux] INFO: Closing all muxed channels
0082212036 [mux] INFO: Closing mux channel 1
0082212037 [mux] INFO: Closing mux channel 2
0082212037 [mux] INFO: Muxed channel 3 already closed
0082212038 [mux] INFO: Muxed channel 4 already closed
0082212038 [mux] INFO: GSM07.10 muxer thread exiting
0082212039 [ncp.client] TRACE: NCP connection state changed: 1
0082212039 [net.pppncp] TRACE: NCP event 2
0082212040 [net.pppncp] TRACE: State changed event: 1
0082212040 [mux] INFO: GSM07.10 muxer stopped
0082212041 [ncp.client] TRACE: Setting UART voltage translator state 0
0082212042 [ncp.client] TRACE: Soft power off modem successfully
0082212042 [ncp.client] TRACE: Deinit modem serial.
0082212043 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0082212043 [ncp.client] ERROR: Failed to enter data mode
0082212044 [net.ppp.client] ERROR: Failed to dial
0082212044 [net.ppp.client] TRACE: State CONNECTING -> CONNECT
0082212045 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0082212046 [net.ppp.client] TRACE: State CONNECT -> DISCONNECT
0082212046 [net.ppp.client] TRACE: State DISCONNECT -> DISCONNECTING
0082212046 [net.ppp.client] TRACE: PPP thread event ERROR data=5
0082212047 [net.pppncp] ERROR: PPP error event data=5
0082212047 [net.ppp.client] TRACE: PPP thread event DOWN data=0
0082212048 [net.ppp.client] TRACE: State DISCONNECTING -> DISCONNECTED
0082212048 [net.ppp.client] TRACE: State DISCONNECTED -> READY
0082212144 [ncp.client] TRACE: Modem already off
0082212144 [ncp.client] TRACE: Setting UART voltage translator state 0
0082212145 [ncp.client] TRACE: Soft power off modem successfully
0082212145 [ncp.client] TRACE: Deinit modem serial.
0082212146 [ncp.client] TRACE: NCP connection state changed: 0
0082212146 [net.pppncp] TRACE: NCP event 2
0082212147 [net.pppncp] TRACE: State changed event: 0
0082212147 [ncp.client] TRACE: NCP state changed: 0
0082212148 [net.pppncp] TRACE: NCP event 1
0082212148 [ncp.client] TRACE: Powering modem on, ncpId: 0x44
0082212149 [net.pppncp] TRACE: NCP event 3
0082212149 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0082212150 [system.nm] TRACE: Interface 4 power state changed: 4
0082212148 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0082212300 [net.pppncp] TRACE: NCP event 3
0082212300 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0082212301 [system.nm] TRACE: Interface 4 power state changed: 2
0082212302 [ncp.client] TRACE: Modem powered on
0082212302 [ncp.client] TRACE: Setting UART voltage translator state 1
0082212402 [ncp.client] TRACE: Setting UART voltage translator state 0
0082212502 [ncp.client] TRACE: Setting UART voltage translator state 1
0082213503 [ncp.at] TRACE: > AT
0082214503 [ncp.at] TRACE: > AT
0082215503 [ncp.at] TRACE: > AT
0082216503 [ncp.at] TRACE: > AT
0082216506 [ncp.at] TRACE: < OK
0082216506 [ncp.client] TRACE: NCP ready to accept AT commands
0082216507 [ncp.at] TRACE: > AT
0082216508 [ncp.at] TRACE: < OK
0082216508 [ncp.at] TRACE: > ATI9
0082216510 [ncp.at] TRACE: < L0.0.00.00.05.08,A.02.04
0082216510 [ncp.at] TRACE: < OK
0082216510 [ncp.client] TRACE: App firmware: 204
0082216511 [ncp.at] TRACE: > AT+UGPIOC?
0082216513 [ncp.at] TRACE: < +UGPIOC:
0082216513 [ncp.at] TRACE: < 7,255
0082216514 [ncp.at] TRACE: < 16,255
0082216514 [ncp.at] TRACE: < 19,255
0082216515 [ncp.at] TRACE: < 23,0
0082216515 [ncp.at] TRACE: < 24,255
0082216516 [ncp.at] TRACE: < 25,255
0082216516 [ncp.at] TRACE: < 42,255
0082216517 [ncp.at] TRACE: < OK
0082216517 [ncp.at] TRACE: > AT+UGPIOR=23
0082216519 [ncp.at] TRACE: < +UGPIOR: 23,1
0082216520 [ncp.at] TRACE: < OK
0082216520 [ncp.client] INFO: Using internal SIM card
0082216521 [ncp.at] TRACE: > AT+CPIN?
0082216523 [ncp.at] TRACE: < +CME ERROR: SIM not inserted
0082217523 [ncp.at] TRACE: > AT+CPIN?
0082221362 [ncp.at] TRACE: < +CPIN: READY
0082221363 [ncp.at] TRACE: < OK
0082221363 [ncp.at] TRACE: > AT+CCID
0082221366 [ncp.at] TRACE: < +CCID: 89014103272806309015
0082221367 [ncp.at] TRACE: < OK
0082221367 [ncp.at] TRACE: > AT+IFC?
0082221369 [ncp.at] TRACE: < +IFC: 2,2
0082221369 [ncp.at] TRACE: < OK
0082221370 [ncp.at] TRACE: > AT+CFUN=0,0
0082222148 [ncp.at] TRACE: < OK
0082222148 [ncp.at] TRACE: > AT+CFUN=1,0
0082222151 [ncp.at] TRACE: < OK
0082222152 [ncp.at] TRACE: > AT+CPIN?
0082222154 [ncp.at] TRACE: < +CPIN: READY
0082222154 [ncp.at] TRACE: < OK
0082222155 [ncp.at] TRACE: > AT+CCID
0082222157 [ncp.at] TRACE: < +CCID: 89014103272806309015
0082222158 [ncp.at] TRACE: < OK
0082222158 [ncp.at] TRACE: > AT+IFC?
0082222160 [ncp.at] TRACE: < +IFC: 2,2
0082222161 [ncp.at] TRACE: < OK
0082222161 [ncp.at] TRACE: > AT+IFC=2,2
0082222164 [ncp.at] TRACE: < OK
0082222164 [ncp.at] TRACE: > AT
0082222165 [ncp.at] TRACE: < OK
0082222166 [ncp.at] TRACE: > AT+IPR=460800
0082222174 [ncp.at] TRACE: < OK
0082223174 [ncp.at] TRACE: > AT
0082223177 [ncp.at] TRACE: < OK
0082223177 [ncp.at] TRACE: > AT+CCID
0082223180 [ncp.at] TRACE: < +CCID: 89014103272806309015
0082223181 [ncp.at] TRACE: < OK
0082223181 [ncp.at] TRACE: > AT+CIMI
0082223183 [ncp.at] TRACE: < 310410280630901
0082223183 [ncp.at] TRACE: < OK
0082223184 [ncp.at] TRACE: > AT+UMNOPROF?
0082223185 [ncp.at] TRACE: < +UMNOPROF: 2
0082223185 [ncp.at] TRACE: < OK
0082223186 [ncp.at] TRACE: > AT+COPS=3,2
0082223187 [ncp.at] TRACE: < OK
0082223187 [ncp.at] TRACE: > AT+CGEREP=1,0
0082223189 [ncp.at] TRACE: < OK
0082223189 [ncp.at] TRACE: > AT+URAT?
0082223192 [ncp.at] TRACE: < +CME ERROR: Operation not supported
0082223192 [ncp.at] TRACE: > AT+CPSMS?
0082223196 [ncp.at] TRACE: < +CPSMS:0,,,"10000101","00000011"
0082223196 [ncp.at] TRACE: < OK
0082223197 [ncp.at] TRACE: > AT+CEDRXS?
0082223199 [ncp.at] TRACE: < +CEDRXS:
0082223199 [ncp.at] TRACE: < OK
0082223199 [ncp.at] TRACE: > AT+CMUX=0,0,,1509,,,,,
0082223204 [ncp.at] TRACE: < OK
0082223204 [mux] INFO: Starting GSM07.10 muxer
0082223205 [mux] INFO: Openning mux channel 0
0082223206 [mux] INFO: GSM07.10 muxer thread started
0082223208 [mux] INFO: Openning mux channel 1
0082224476 [ncp.at] TRACE: > AT
0082224477 [ncp.at] TRACE: < +CEREG: 0
0082224477 [ncp.at] TRACE: < +CGEV: ME DETACH
0082224481 [ncp.at] TRACE: < OK
0082224481 [ncp.client] TRACE: NCP state changed: 1
0082224482 [net.pppncp] TRACE: NCP event 1
0082224483 [net.ppp.client] TRACE: PPP thread event ADM_UP data=0
0082224486 [ncp.at] TRACE: > AT
0082224491 [ncp.at] TRACE: < OK
0082224492 [ncp.at] TRACE: > AT+CFUN?
0082224496 [ncp.at] TRACE: < +CFUN: 1
0082224497 [ncp.at] TRACE: < OK
0082224498 [ncp.at] TRACE: > AT+CCID
0082224503 [ncp.at] TRACE: < +CCID: 89014103272806309015
0082224503 [ncp.at] TRACE: < OK
0082224504 [ncp.at] TRACE: > AT+CIMI
0082224509 [ncp.at] TRACE: < 310410280630901
0082224509 [ncp.at] TRACE: < OK
0082224510 [ncp.at] TRACE: > AT+CGDCONT?
0082224518 [ncp.at] TRACE: < +CGDCONT: 1,"IP","10569.mcs","0.0.0.0",0,0,0,0
0082224518 [ncp.at] TRACE: < OK
0082224519 [ncp.at] TRACE: > AT+CFUN?
0082224524 [ncp.at] TRACE: < +CFUN: 1
0082224524 [ncp.at] TRACE: < OK
0082224525 [ncp.at] TRACE: > AT+CEREG=2
0082224530 [ncp.at] TRACE: < OK
0082224530 [ncp.client] TRACE: NCP connection state changed: 1
0082224530 [net.pppncp] TRACE: NCP event 2
0082224531 [net.pppncp] TRACE: State changed event: 1
0082224532 [ncp.at] TRACE: > AT+COPS?
0082224532 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0082224537 [ncp.at] TRACE: < +COPS: 0
0082224537 [ncp.at] TRACE: < OK
0082224538 [ncp.at] TRACE: > AT+CEREG?
0082224542 [ncp.at] TRACE: < +CEREG: 2,2
0082224543 [ncp.at] TRACE: < OK
0082239544 [ncp.at] TRACE: > AT+CEREG?
0082239552 [ncp.at] TRACE: < +CEREG: 2,1,"900E","509F211",7
0082239553 [ncp.at] TRACE: < OK
0082239554 [ncp.at] TRACE: > AT+UCGED=5
0082239554 [ncp.at] TRACE: < +CEREG: 1,"900E","509F211",7
0082239561 [ncp.at] TRACE: < OK
0082239562 [ncp.at] TRACE: > AT+UCGED?
0082239574 [ncp.at] TRACE: < +RSRP: 443,5110,"-099.40",343,5110,"-095.90",406,5110,"-100.10",441,5110,"-098.90",
0082239575 [ncp.at] TRACE: < +RSRQ: 443,5110,"-19.80",343,5110,"-17.70",406,5110,"-20.00",441,5110,"-20.00",
0082239575 [ncp.at] TRACE: < OK
0082239675 [ncp.client] TRACE: NCP connection state changed: 2
0082239676 [mux] INFO: Openning mux channel 2
0082240841 [net.pppncp] TRACE: NCP event 100
0082240841 [net.pppncp] TRACE: New auth info
0082240844 [net.pppncp] TRACE: NCP event 2
0082240844 [net.pppncp] TRACE: State changed event: 2
0082240845 [net.ppp.client] TRACE: PPP thread event LOWER_UP data=0
0082240846 [net.ppp.client] TRACE: State READY -> CONNECT
0082240847 [net.ppp.client] TRACE: State CONNECT -> CONNECTING
0082240846 [ncp.at] TRACE: > AT+CIMI
0082240854 [ncp.at] TRACE: < 310410280630901
0082240854 [ncp.at] TRACE: < OK
0082240855 [ncp.at] TRACE: > AT
0082240863 [ncp.at] TRACE: < OK
0082240863 [ncp.at] TRACE: > AT+CGATT?
0082240871 [ncp.at] TRACE: < +CGATT: 1
0082240871 [ncp.at] TRACE: < OK
0082241873 [ncp.at] TRACE: > AT
0082241880 [ncp.at] TRACE: < OK
0082241880 [ncp.at] TRACE: > ATD*99***1#
0082241889 [ncp.at] TRACE: < CONNECT 150000000
0082241889 [net.ppp.client] TRACE: PPP phase -> Initialize
0082241890 [net.ppp.client] TRACE: PPP phase -> Establish
0082241890 [lwip.ppp] TRACE: sent [LCP ConfReq id=0x18 <asyncmap 0x0> <magic 0x64c0616b> <pcomp> <accomp>]
0082242639 [lwip.ppp] TRACE: rcvd [LCP ConfReq id=0x0 <asyncmap 0x0> <auth chap MD5> <magic 0x3d20ac69> <pcomp> <accomp>]
0082242640 [lwip.ppp] TRACE: sent [LCP ConfAck id=0x0 <asyncmap 0x0> <auth chap MD5> <magic 0x3d20ac69> <pcomp> <accomp>]
0082242643 [lwip.ppp] TRACE: rcvd [LCP ConfAck id=0x18 <asyncmap 0x0> <magic 0x64c0616b> <pcomp> <accomp>]
0082242644 [lwip.ppp] TRACE: sent [LCP EchoReq id=0x0 magic=0x64c0616b]
0082242645 [net.ppp.client] TRACE: PPP phase -> Authenticate
0082243918 [lwip.ppp] TRACE: rcvd [LCP DiscReq id=0x1 magic=0x3d20ac69]
0082243921 [lwip.ppp] TRACE: rcvd [CHAP Challenge id=0x1 <ca311c06e9f483099c76d63afefccefe>, name = "UMTS_CHAP_SRVR"]
0082243923 [lwip.ppp] TRACE: sent [CHAP Response id=0x1 <997c07bd09d94ea38961e1fe6cff53da>, name = ""]
0082243925 [lwip.ppp] TRACE: rcvd [LCP EchoRep id=0x0 magic=0x3d20ac69 64 c0 61 6b]
0082245197 [lwip.ppp] TRACE: rcvd [CHAP Success id=0x1 ""]
0082245198 [net.ppp.client] TRACE: PPP phase -> Network
0082245198 [lwip.ppp] TRACE: sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <msdns1 8.8.8.8> <msdns2 8.8.4.4>]
0082246478 [lwip.ppp] TRACE: rcvd [IPCP ConfReq id=0x0]
0082246479 [lwip.ppp] TRACE: sent [IPCP ConfAck id=0x0]
0082246481 [lwip.ppp] TRACE: rcvd [IPCP ConfNak id=0x1 <addr 10.210.71.77> <msdns1 174.47.40.106> <msdns2 174.47.20.106>]
0082246482 [lwip.ppp] TRACE: sent [IPCP ConfReq id=0x2 <addr 10.210.71.77> <msdns1 174.47.40.106> <msdns2 174.47.20.106>]
0082247644 [lwip.ppp] TRACE: sent [LCP EchoReq id=0x1 magic=0x64c0616b]
0082247654 [lwip.ppp] TRACE: rcvd [IPCP ConfReq id=0x1]
0082247655 [lwip.ppp] TRACE: sent [IPCP ConfAck id=0x1]
0082247658 [lwip.ppp] TRACE: rcvd [IPCP ConfAck id=0x2 <addr 10.210.71.77> <msdns1 174.47.40.106> <msdns2 174.47.20.106>]
0082247663 [system.nm] INFO: State changed: IFACE_UP -> IFACE_LINK_UP
0082247664 [net.ppp.client] TRACE: PPP thread event UP data=0
0082247665 [net.ppp.client] TRACE: State CONNECTING -> CONNECTED
0082247665 [net.pppncp] TRACE: Negotiated MTU: 1500
0082247666 [system.nm] INFO: State changed: IFACE_LINK_UP -> IP_CONFIGURED
0082247667 [net.ppp.client] TRACE: PPP phase -> Running
0082247667 [system] INFO: Cloud: connecting
0082247672 [system] INFO: Cloud socket connected
0082247672 [comm.protocol.handshake] INFO: Establish secure connection
0082247679 [comm.dtls] INFO: session has 0 uses
0082247695 [comm.dtls] INFO: (CMPL,RENEG,NO_SESS,ERR) restoreStatus=0
0082247696 [comm.dtls] INFO: out_ctr 0,1,0,0,0,0,4,73, next_coap_id=809
0082247697 [comm.dtls] INFO: restored session from persisted session data. next_msg_id=2057
0082247699 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 2
0082247794 [lwip.ppp] TRACE: rcvd [IPCP ConfReq id=0x2]
0082247795 [lwip.ppp] TRACE: sent [IPCP ConfAck id=0x2]
0082248114 [ncp.at] TRACE: > AT+CFUN?
0082248121 [ncp.at] TRACE: < +CFUN: 1
0082248122 [ncp.at] TRACE: < OK
0082248123 [ncp.at] TRACE: > AT+CCID
0082248132 [ncp.at] TRACE: < +CCID: 89014103272806309015
0082248133 [ncp.at] TRACE: < OK
0082248134 [ncp.at] TRACE: > AT+CGSN
0082248143 [ncp.at] TRACE: < 354724644174630
0082248143 [ncp.at] TRACE: < OK
0082248145 [ncp.at] TRACE: > ATI9
0082248153 [ncp.at] TRACE: < L0.0.00.00.05.08,A.02.04
0082248154 [ncp.at] TRACE: < OK
0082248154 [comm.protocol.handshake] INFO: Skipping HELLO message
0082248159 [comm.coap] TRACE: Sending CoAP message
