Boron 404X not connecting after setup
Hello, I have a Boron 404X that is failing to connect after setting it up for the first time. The console shows the SIM as active and I tried deactivating and reactivating the SIM. I also waited a day and it still fails to connect. Logs are below and I can share device ID if needed. Thanks for the help!
Logs:
  • log 1 - registration denied
  • log 2 - a day later at a different location - registration occasionally succeeds, but then loses registration and fails to enter data mode / fails to dial
Log 1:
0000000323 [system.nm] TRACE: Request to power on interface 4
0000000323 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000000324 [ncp.client] TRACE: Already on
0000000325 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
0000000524 [ncp.client] TRACE: Muxer is not currently running
0000000525 [ncp.client] TRACE: Initialized muxer @ 460800 baudrate
0000000526 [mux] INFO: Starting GSM07.10 muxer
0000000527 [mux] INFO: GSM07.10 muxer thread started
0000000827 [mux] INFO: Stopping GSM07.10 muxer
0000000827 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000000828 [mux] INFO: Closing all muxed channels
0000000828 [mux] INFO: Muxed channel 1 already closed
0000000829 [mux] INFO: Muxed channel 2 already closed
0000000830 [mux] INFO: Muxed channel 3 already closed
0000000830 [mux] INFO: Muxed channel 4 already closed
0000000831 [mux] INFO: Sending CLD (multiplexer close down)
0000000833 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000000834 [mux] INFO: GSM07.10 muxer thread exiting
0000000835 [mux] INFO: GSM07.10 muxer stopped
0000000836 [ncp.client] TRACE: Initialized muxer @ 115200 baudrate
0000000836 [mux] INFO: Starting GSM07.10 muxer
0000000837 [mux] INFO: GSM07.10 muxer thread started
0000001137 [mux] INFO: Stopping GSM07.10 muxer
0000001137 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000001138 [mux] INFO: Closing all muxed channels
0000001138 [mux] INFO: Muxed channel 1 already closed
0000001139 [mux] INFO: Muxed channel 2 already closed
0000001140 [mux] INFO: Muxed channel 3 already closed
0000001140 [mux] INFO: Muxed channel 4 already closed
0000001141 [mux] INFO: Sending CLD (multiplexer close down)
0000002042 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000002092 [mux] INFO: GSM07.10 muxer thread exiting
0000002092 [mux] INFO: GSM07.10 muxer stopped
0000002094 [ncp.at] TRACE: > AT
0000002096 [ncp.at] TRACE: < OK
0000002096 [ncp.client] TRACE: NCP ready to accept AT commands
0000002097 [ncp.at] TRACE: > AT
0000002099 [ncp.at] TRACE: < OK
0000002100 [ncp.at] TRACE: > ATI9
0000002103 [ncp.at] TRACE: < 03.15,A00.01
0000002103 [ncp.at] TRACE: < OK
0000002104 [ncp.client] TRACE: App firmware: 1
0000002104 [ncp.at] TRACE: > AT+UGPIOC?
0000002107 [ncp.at] TRACE: < +UGPIOC:
0000002107 [ncp.at] TRACE: < 16,255
0000002108 [ncp.at] TRACE: < 19,255
0000002108 [ncp.at] TRACE: < 23,0
0000002109 [ncp.at] TRACE: < 24,255
0000002110 [ncp.at] TRACE: < 25,255
0000002110 [ncp.at] TRACE: < 33,255
0000002111 [ncp.at] TRACE: < 42,255
0000002111 [ncp.at] TRACE: < 46,255
0000002112 [ncp.at] TRACE: < OK
0000002113 [ncp.at] TRACE: > AT+UGPIOR=23
0000002116 [ncp.at] TRACE: < +UGPIOR: 23,1
0000002117 [ncp.at] TRACE: < OK
0000002117 [ncp.client] INFO: Using internal SIM card
0000002118 [ncp.at] TRACE: > AT+CPIN?
0000002121 [ncp.at] TRACE: < +CPIN: READY
0000002121 [ncp.at] TRACE: < OK
0000002122 [ncp.at] TRACE: > AT+CCID
0000002145 [ncp.at] TRACE: < +CCID: 89883070000036137378
0000002145 [ncp.at] TRACE: < OK
0000002146 [ncp.at] TRACE: > AT+IFC?
0000002149 [ncp.at] TRACE: < +IFC: 2,2
0000002149 [ncp.at] TRACE: < OK
0000002150 [ncp.at] TRACE: > AT+IFC=2,2
0000002153 [ncp.at] TRACE: < OK
0000002153 [ncp.at] TRACE: > AT
0000002155 [ncp.at] TRACE: < OK
0000002156 [ncp.at] TRACE: > AT+IPR=460800
0000002159 [ncp.at] TRACE: < OK
0000003159 [ncp.at] TRACE: > AT
0000003161 [ncp.at] TRACE: < OK
0000003161 [ncp.at] TRACE: > AT+CCID
0000003187 [ncp.at] TRACE: < +CCID: 89883070000036137378
0000003187 [ncp.at] TRACE: < OK
0000003189 [ncp.at] TRACE: > AT+UMNOPROF?
0000003192 [ncp.at] TRACE: < +UMNOPROF: 90
0000003193 [ncp.at] TRACE: < OK
0000003194 [ncp.at] TRACE: > AT+UBANDMASK?
0000003197 [ncp.at] TRACE: < +UBANDMASK: 0,185473183,1048578
0000003198 [ncp.at] TRACE: < OK
0000003199 [ncp.at] TRACE: > AT+COPS=3,2
0000003202 [ncp.at] TRACE: < OK
0000003202 [ncp.at] TRACE: > AT+CGEREP=1,0
0000003205 [ncp.at] TRACE: < OK
0000003205 [ncp.at] TRACE: > AT+URAT?
0000003208 [ncp.at] TRACE: < +URAT: 7
0000003208 [ncp.at] TRACE: < OK
0000003209 [ncp.at] TRACE: > AT+CPSMS?
0000003213 [ncp.at] TRACE: < +CPSMS: 0,,,"00010011","00000011"
0000003213 [ncp.at] TRACE: < OK
0000003214 [ncp.at] TRACE: > AT+CEDRXS?
0000003217 [ncp.at] TRACE: < +CEDRXS: 4,"0000"
0000003218 [ncp.at] TRACE: < OK
0000003218 [ncp.at] TRACE: > AT+UPSV?
0000003221 [ncp.at] TRACE: < +UPSV: 1,2000,1
0000003221 [ncp.at] TRACE: < OK
0000003222 [ncp.at] TRACE: > AT+UPSV=0
0000003225 [ncp.at] TRACE: < OK
0000003225 [ncp.at] TRACE: > AT+UPSV=1
0000003228 [ncp.at] TRACE: < OK
0000003228 [ncp.at] TRACE: > AT+CMUX=0,0,,1509,,,,,
0000003232 [ncp.at] TRACE: < OK
0000003232 [mux] INFO: Starting GSM07.10 muxer
0000003233 [mux] INFO: Opening mux channel 0
0000003234 [mux] INFO: GSM07.10 muxer thread started
0000003237 [mux] INFO: Opening mux channel 1
0000004505 [ncp.at] TRACE: > AT
0000004509 [ncp.at] TRACE: < OK
0000004509 [ncp.client] TRACE: NCP state changed: 1
0000004510 [net.pppncp] TRACE: NCP event 1
0000004510 [app] INFO: cellular is on
0000004512 [ncp.at] TRACE: > AT+CCID
0000004536 [ncp.at] TRACE: < +CCID: 89883070000036137378
0000004537 [ncp.at] TRACE: < OK
0000004541 [ncp.at] TRACE: > AT+CGMI
0000004543 [ncp.at] TRACE: < u-blox
0000004543 [ncp.at] TRACE: < OK
0000004545 [ncp.at] TRACE: > AT+CGMM
0000004549 [ncp.at] TRACE: < SARA-R510S
0000004549 [ncp.at] TRACE: < OK
0000004551 [ncp.at] TRACE: > AT+CGMR
0000004555 [ncp.at] TRACE: < 03.15
0000004555 [ncp.at] TRACE: < OK
0000004557 [ncp.at] TRACE: > AT+CGSN
0000004561 [ncp.at] TRACE: < 351457830728520
0000004563 [ncp.at] TRACE: < OK
0000005226 [app] INFO: Auto-connect disabled
0000005700 [ncp.at] TRACE: > AT+CFUN?
0000005704 [ncp.at] TRACE: < +CFUN: 1,7
0000005704 [ncp.at] TRACE: < OK
0000005706 [ncp.at] TRACE: > AT+CCID
0000005730 [ncp.at] TRACE: < +CCID: 89883070000036137378
0000005731 [ncp.at] TRACE: < OK
0000005732 [ncp.at] TRACE: > AT+CGSN
0000005736 [ncp.at] TRACE: < 351457830728520
0000005737 [ncp.at] TRACE: < OK
0000005738 [ncp.at] TRACE: > ATI9
0000005741 [ncp.at] TRACE: < 03.15,A00.01
0000005741 [ncp.at] TRACE: < OK
0000006106 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
0000006109 [net.ppp.client] TRACE: PPP thread event ADM_UP data=0
0000006109 [net.ppp.client] TRACE: State NONE -> READY
0000006112 [ncp.at] TRACE: > AT+CFUN?
0000006116 [ncp.at] TRACE: < +CFUN: 1,7
0000006117 [ncp.at] TRACE: < OK
0000006117 [ncp.at] TRACE: > AT+CCID
0000006119 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
0000006141 [ncp.at] TRACE: < +CCID: 89883070000036137378
0000006142 [ncp.at] TRACE: < OK
0000006143 [ncp.at] TRACE: > AT+CGDCONT?
0000006148 [ncp.at] TRACE: < +CGDCONT: 1,"IP","super","0.0.0.0",0,0,0,2,0,0,0,0,0,0,0
0000006149 [ncp.at] TRACE: < OK
0000006150 [ncp.at] TRACE: > AT+CFUN?
0000006154 [ncp.at] TRACE: < +CFUN: 1,7
0000006155 [ncp.at] TRACE: < OK
0000006155 [ncp.at] TRACE: > AT+CEREG=2
0000006158 [ncp.at] TRACE: < OK
0000006159 [ncp.client] TRACE: NCP connection state changed: 1
0000006159 [net.pppncp] TRACE: NCP event 2
0000006160 [net.pppncp] TRACE: State changed event: 1
0000006161 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0000006162 [ncp.at] TRACE: > AT+COPS?
0000006166 [ncp.at] TRACE: < +COPS: 0
0000006167 [ncp.at] TRACE: < OK
0000006167 [ncp.at] TRACE: > AT+CEREG?
0000006171 [ncp.at] TRACE: < +CEREG: 2,0
0000006171 [ncp.at] TRACE: < OK
0000021172 [ncp.at] TRACE: > AT+CEREG?
0000021176 [ncp.at] TRACE: < +CEREG: 2,0
0000021177 [ncp.at] TRACE: < OK
0000021178 [ncp.at] TRACE: > AT+UCGED?
0000021184 [ncp.at] TRACE: < +UCGED: 2
0000021185 [ncp.at] TRACE: < 6,2,fff,fff
0000021185 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000021186 [ncp.at] TRACE: < OK
0000036187 [ncp.at] TRACE: > AT+CEREG?
0000036191 [ncp.at] TRACE: < +CEREG: 2,0
0000036192 [ncp.at] TRACE: < OK
0000036193 [ncp.at] TRACE: > AT+UCGED?
0000036199 [ncp.at] TRACE: < +UCGED: 2
0000036200 [ncp.at] TRACE: < 6,2,fff,fff
0000036200 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000036201 [ncp.at] TRACE: < OK
0000051202 [ncp.at] TRACE: > AT+CEREG?
0000051206 [ncp.at] TRACE: < +CEREG: 2,0
0000051207 [ncp.at] TRACE: < OK
0000051208 [ncp.at] TRACE: > AT+UCGED?
0000051214 [ncp.at] TRACE: < +UCGED: 2
0000051215 [ncp.at] TRACE: < 6,2,fff,fff
0000051215 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000051216 [ncp.at] TRACE: < OK
0000066217 [ncp.at] TRACE: > AT+CIMI
0000066265 [ncp.at] TRACE: < 232104853323465
0000066266 [ncp.at] TRACE: < OK
0000066267 [ncp.at] TRACE: > AT+CEREG?
0000066270 [ncp.at] TRACE: < +CEREG: 2,0
0000066271 [ncp.at] TRACE: < OK
0000066272 [ncp.at] TRACE: > AT+UCGED?
0000066278 [ncp.at] TRACE: < +UCGED: 2
0000066279 [ncp.at] TRACE: < 6,2,fff,fff
0000066279 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000066280 [ncp.at] TRACE: < OK
0000071381 [ncp.at] TRACE: < +CEREG: 3
0000081281 [ncp.at] TRACE: > AT+CEREG?
0000081285 [ncp.at] TRACE: < +CEREG: 2,3
0000081286 [ncp.at] TRACE: < OK
0000081287 [ncp.at] TRACE: > AT+UCGED?
0000081293 [ncp.at] TRACE: < +UCGED: 2
0000081294 [ncp.at] TRACE: < 6,2,fff,fff
0000081294 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000081296 [ncp.at] TRACE: < OK
0000096296 [ncp.at] TRACE: > AT+CEREG?
0000096300 [ncp.at] TRACE: < +CEREG: 2,3
0000096301 [ncp.at] TRACE: < OK
0000096302 [ncp.at] TRACE: > AT+UCGED?
0000096308 [ncp.at] TRACE: < +UCGED: 2
0000096309 [ncp.at] TRACE: < 6,2,fff,fff
0000096310 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000096311 [ncp.at] TRACE: < OK
0000111311 [ncp.at] TRACE: > AT+CEREG?
0000111315 [ncp.at] TRACE: < +CEREG: 2,3
0000111316 [ncp.at] TRACE: < OK
0000111317 [ncp.at] TRACE: > AT+UCGED?
0000111323 [ncp.at] TRACE: < +UCGED: 2
0000111324 [ncp.at] TRACE: < 6,2,fff,fff
0000111325 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000111326 [ncp.at] TRACE: < OK
0000336381 [ncp.client] TRACE: Sticky not registering EPS state for 30 s, PLMN reselection
0000336382 [ncp.at] TRACE: > AT+COPS=0,2
0000646409 [net.pppncp] TRACE: NCP event 1
0000646409 [mux] INFO: Stopping GSM07.10 muxer
0000646410 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000646411 [mux] INFO: Closing all muxed channels
0000646411 [mux] INFO: Closing mux channel 1
0000646412 [mux] INFO: Muxed channel 2 already closed
0000646412 [mux] INFO: Muxed channel 3 already closed
0000646413 [mux] INFO: Muxed channel 4 already closed
0000647681 [mux] INFO: Sending CLD (multiplexer close down)
0000647684 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000647684 [mux] INFO: GSM07.10 muxer thread exiting
0000647685 [mux] INFO: GSM07.10 muxer stopped
0000647686 [net.pppncp] TRACE: NCP event 3
0000647686 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000647687 [system.nm] TRACE: Interface 4 power state changed: POWERING_DOWN
0000647688 [ncp.client] TRACE: Powering off using hardware control
0000652828 [net.pppncp] TRACE: NCP event 3
0000652828 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000652829 [system.nm] TRACE: Interface 4 power state changed: DOWN
0000652830 [ncp.client] TRACE: Powered off
Log 2:
0000000315 [system.nm] TRACE: Request to power on interface 4
0000000315 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000000316 [ncp.client] TRACE: Already on
0000000316 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
0000000516 [ncp.client] TRACE: Muxer is not currently running
0000000517 [ncp.client] TRACE: Initialized muxer @ 460800 baudrate
0000000517 [mux] INFO: Starting GSM07.10 muxer
0000000519 [mux] INFO: GSM07.10 muxer thread started
0000000819 [mux] INFO: Stopping GSM07.10 muxer
0000000819 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000000820 [mux] INFO: Closing all muxed channels
0000000820 [mux] INFO: Muxed channel 1 already closed
0000000821 [mux] INFO: Muxed channel 2 already closed
0000000822 [mux] INFO: Muxed channel 3 already closed
0000000822 [mux] INFO: Muxed channel 4 already closed
0000000823 [mux] INFO: Sending CLD (multiplexer close down)
0000000825 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000000826 [mux] INFO: GSM07.10 muxer thread exiting
0000000827 [mux] INFO: GSM07.10 muxer stopped
0000000827 [ncp.client] TRACE: Initialized muxer @ 115200 baudrate
0000000828 [mux] INFO: Starting GSM07.10 muxer
0000000829 [mux] INFO: GSM07.10 muxer thread started
0000001129 [mux] INFO: Stopping GSM07.10 muxer
0000001129 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000001130 [mux] INFO: Closing all muxed channels
0000001130 [mux] INFO: Muxed channel 1 already closed
0000001131 [mux] INFO: Muxed channel 2 already closed
0000001132 [mux] INFO: Muxed channel 3 already closed
0000001132 [mux] INFO: Muxed channel 4 already closed
0000001133 [mux] INFO: Sending CLD (multiplexer close down)
0000002034 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000002084 [mux] INFO: GSM07.10 muxer thread exiting
0000002084 [mux] INFO: GSM07.10 muxer stopped
0000002086 [ncp.at] TRACE: > AT
0000002088 [ncp.at] TRACE: < OK
0000002089 [ncp.client] TRACE: NCP ready to accept AT commands
0000002090 [ncp.at] TRACE: > AT
0000002092 [ncp.at] TRACE: < OK
0000002093 [ncp.at] TRACE: > ATI9
0000002096 [ncp.at] TRACE: < 03.15,A00.01
0000002097 [ncp.client] TRACE: App firmware: 1
0000002097 [ncp.at] TRACE: > AT+UGPIOC?
0000002099 [ncp.at] TRACE: < +UGPIOC:
0000002100 [ncp.at] TRACE: < 16,255
0000002101 [ncp.at] TRACE: < 19,255
0000002101 [ncp.at] TRACE: < 23,0
0000002102 [ncp.at] TRACE: < 24,255
0000002102 [ncp.at] TRACE: < 25,255
0000002103 [ncp.at] TRACE: < 33,255
0000002104 [ncp.at] TRACE: < 42,255
0000002104 [ncp.at] TRACE: < 46,255
0000002105 [ncp.at] TRACE: < OK
0000002105 [ncp.at] TRACE: > AT+UGPIOR=23
0000002109 [ncp.at] TRACE: < +UGPIOR: 23,1
0000002109 [ncp.at] TRACE: < OK
0000002110 [ncp.client] INFO: Using internal SIM card
0000002110 [ncp.at] TRACE: > AT+CPIN?
0000002113 [ncp.at] TRACE: < +CPIN: READY
0000002113 [ncp.at] TRACE: < OK
0000002114 [ncp.at] TRACE: > AT+CCID
0000002156 [ncp.at] TRACE: < +CCID: 89883070000036137378
0000002156 [ncp.at] TRACE: < OK
0000002157 [ncp.at] TRACE: > AT+IFC?
0000002160 [ncp.at] TRACE: < +IFC: 2,2
0000002160 [ncp.at] TRACE: < OK
0000002161 [ncp.at] TRACE: > AT+IFC=2,2
0000002164 [ncp.at] TRACE: < OK
0000002164 [ncp.at] TRACE: > AT
0000002166 [ncp.at] TRACE: < OK
0000002167 [ncp.at] TRACE: > AT+IPR=460800
0000002169 [ncp.at] TRACE: < OK
0000003170 [ncp.at] TRACE: > AT
0000003172 [ncp.at] TRACE: < OK
0000003173 [ncp.at] TRACE: > AT+CCID
0000003196 [ncp.at] TRACE: < +CCID: 89883070000036137378
0000003196 [ncp.at] TRACE: < OK
0000003198 [ncp.at] TRACE: > AT+UMNOPROF?
0000003201 [ncp.at] TRACE: < +UMNOPROF: 90
0000003202 [ncp.at] TRACE: > AT+UBANDMASK?
0000003206 [ncp.at] TRACE: < +UBANDMASK: 0,185473183,1048578
0000003207 [ncp.at] TRACE: < OK
0000003208 [ncp.at] TRACE: > AT+COPS=3,2
0000003211 [ncp.at] TRACE: < OK
0000003211 [ncp.at] TRACE: > AT+CGEREP=1,0
0000003214 [ncp.at] TRACE: < OK
0000003214 [ncp.at] TRACE: > AT+URAT?
0000003216 [ncp.at] TRACE: < +URAT: 7
0000003217 [ncp.at] TRACE: < OK
0000003218 [ncp.at] TRACE: > AT+CPSMS?
0000003221 [ncp.at] TRACE: < +CPSMS: 0,,,"00010011","00000011"
0000003222 [ncp.at] TRACE: < OK
0000003223 [ncp.at] TRACE: > AT+CEDRXS?
0000003226 [ncp.at] TRACE: < +CEDRXS: 4,"0000"
0000003227 [ncp.at] TRACE: < OK
0000003227 [ncp.at] TRACE: > AT+UPSV?
0000003230 [ncp.at] TRACE: < +UPSV: 1,2000,1
0000003230 [ncp.at] TRACE: < OK
0000003231 [ncp.at] TRACE: > AT+UPSV=0
0000003234 [ncp.at] TRACE: < OK
0000003234 [ncp.at] TRACE: > AT+UPSV=1
0000003237 [ncp.at] TRACE: < OK
0000003237 [ncp.at] TRACE: > AT+CMUX=0,0,,1509,,,,,
0000003241 [ncp.at] TRACE: < OK
0000003241 [mux] INFO: Starting GSM07.10 muxer
0000003242 [mux] INFO: Opening mux channel 0
0000003243 [mux] INFO: GSM07.10 muxer thread started
0000003246 [mux] INFO: Opening mux channel 1
0000004515 [ncp.at] TRACE: > AT
0000004519 [ncp.at] TRACE: < OK
0000004520 [ncp.client] TRACE: NCP state changed: 1
0000004520 [net.pppncp] TRACE: NCP event 1
0000004521 [app] INFO: cellular is on
0000004523 [ncp.at] TRACE: > AT+CCID
0000004549 [ncp.at] TRACE: < +CCID: 89883070000036137378
0000004551 [ncp.at] TRACE: < OK
0000004553 [ncp.at] TRACE: > AT+CGMI
0000004556 [ncp.at] TRACE: < u-blox
0000004558 [ncp.at] TRACE: < OK
0000004560 [ncp.at] TRACE: > AT+CGMM
0000004564 [ncp.at] TRACE: < SARA-R510S
0000004565 [ncp.at] TRACE: < OK
0000004567 [ncp.at] TRACE: > AT+CGMR
0000004571 [ncp.at] TRACE: < 03.15
0000004571 [ncp.at] TRACE: < OK
0000004572 [ncp.at] TRACE: > AT+CGSN
0000004576 [ncp.at] TRACE: < 351457830728520
0000004577 [ncp.at] TRACE: < OK
0000005698 [ncp.at] TRACE: > AT+CFUN?
0000005702 [ncp.at] TRACE: < +CFUN: 1,7
0000005702 [ncp.at] TRACE: < OK
0000005704 [ncp.at] TRACE: > AT+CCID
0000005727 [ncp.at] TRACE: < +CCID: 89883070000036137378
0000005728 [ncp.at] TRACE: < OK
0000005729 [ncp.at] TRACE: > AT+CGSN
0000005733 [ncp.at] TRACE: < 351457830728520
0000005734 [ncp.at] TRACE: < OK
0000005734 [ncp.at] TRACE: > ATI9
0000005738 [ncp.at] TRACE: < 03.15,A00.01
0000005738 [ncp.at] TRACE: < OK
0000006137 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
0000006140 [net.ppp.client] TRACE: PPP thread event ADM_UP data=0
0000006140 [net.ppp.client] TRACE: State NONE -> READY
0000006144 [ncp.at] TRACE: > AT+CFUN?
0000006145 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
0000006148 [ncp.at] TRACE: < +CFUN: 1,7
0000006148 [ncp.at] TRACE: < OK
0000006149 [ncp.at] TRACE: > AT+CCID
0000006175 [ncp.at] TRACE: < +CCID: 89883070000036137378
0000006176 [ncp.at] TRACE: < OK
0000006177 [ncp.at] TRACE: > AT+CGDCONT?
0000006182 [ncp.at] TRACE: < +CGDCONT: 1,"IP","super","0.0.0.0",0,0,0,2,0,0,0,0,0,0,0
0000006183 [ncp.at] TRACE: < OK
0000006184 [ncp.at] TRACE: > AT+CFUN?
0000006188 [ncp.at] TRACE: < +CFUN: 1,7
0000006188 [ncp.at] TRACE: < OK
0000006189 [ncp.at] TRACE: > AT+CEREG=2
0000006192 [ncp.at] TRACE: < OK
0000006193 [ncp.client] TRACE: NCP connection state changed: 1
0000006193 [net.pppncp] TRACE: NCP event 2
0000006194 [net.pppncp] TRACE: State changed event: 1
0000006195 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0000006196 [ncp.at] TRACE: > AT+COPS?
0000006200 [ncp.at] TRACE: < +COPS: 0
0000006200 [ncp.at] TRACE: < OK
0000006201 [ncp.at] TRACE: > AT+CEREG?
0000006205 [ncp.at] TRACE: < +CEREG: 2,3
0000006205 [ncp.at] TRACE: < OK
0000021206 [ncp.at] TRACE: > AT+CEREG?
0000021210 [ncp.at] TRACE: < +CEREG: 2,3
0000021211 [ncp.at] TRACE: < OK
0000021212 [ncp.at] TRACE: > AT+UCGED?
0000021218 [ncp.at] TRACE: < +UCGED: 2
0000021218 [ncp.at] TRACE: < 6,2,fff,fff
0000021219 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000021220 [ncp.at] TRACE: < OK
0000036221 [ncp.at] TRACE: > AT+CEREG?
0000036223 [ncp.at] TRACE: < +CEREG: 2,3
0000036224 [ncp.at] TRACE: < OK
0000036225 [ncp.at] TRACE: > AT+UCGED?
0000036232 [ncp.at] TRACE: < +UCGED: 2
0000036233 [ncp.at] TRACE: < 6,2,fff,fff
0000036233 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000036234 [ncp.at] TRACE: < OK
0000051235 [ncp.at] TRACE: > AT+CEREG?
0000051239 [ncp.at] TRACE: < +CEREG: 2,3
0000051240 [ncp.at] TRACE: < OK
0000051241 [ncp.at] TRACE: > AT+UCGED?
0000051247 [ncp.at] TRACE: < +UCGED: 2
0000051248 [ncp.at] TRACE: < 6,2,fff,fff
0000051248 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000051249 [ncp.at] TRACE: < OK
0000066250 [ncp.at] TRACE: > AT+CIMI
0000066275 [ncp.at] TRACE: < 234507088328475
0000066276 [ncp.at] TRACE: < OK
0000066277 [ncp.at] TRACE: > AT+CEREG?
0000066281 [ncp.at] TRACE: < +CEREG: 2,3
0000066282 [ncp.at] TRACE: < OK
0000066283 [ncp.at] TRACE: > AT+UCGED?
0000066289 [ncp.at] TRACE: < +UCGED: 2
0000066290 [ncp.at] TRACE: < 6,2,fff,fff
0000066290 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000066291 [ncp.at] TRACE: < OK
0000081292 [ncp.at] TRACE: > AT+CEREG?
0000081296 [ncp.at] TRACE: < +CEREG: 2,3
0000081297 [ncp.at] TRACE: < OK
0000081298 [ncp.at] TRACE: > AT+UCGED?
0000081304 [ncp.at] TRACE: < +UCGED: 2
0000081305 [ncp.at] TRACE: < 6,2,fff,fff
0000081305 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000081306 [ncp.at] TRACE: < OK
0000096307 [ncp.at] TRACE: > AT+CEREG?
0000096311 [ncp.at] TRACE: < +CEREG: 2,3
0000096312 [ncp.at] TRACE: < OK
0000096313 [ncp.at] TRACE: > AT+UCGED?
0000096319 [ncp.at] TRACE: < +UCGED: 2
0000096320 [ncp.at] TRACE: < 6,2,fff,fff
0000096320 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000096322 [ncp.at] TRACE: < OK
0000111322 [ncp.at] TRACE: > AT+CEREG?
0000111325 [ncp.at] TRACE: < +CEREG: 2,3
0000111327 [ncp.at] TRACE: > AT+UCGED?
0000111333 [ncp.at] TRACE: < +UCGED: 2
0000111334 [ncp.at] TRACE: < 6,2,fff,fff
0000111335 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000111336 [ncp.at] TRACE: < OK
0000126336 [ncp.at] TRACE: > AT+CIMI
0000126361 [ncp.at] TRACE: < 234507088328475
0000126361 [ncp.at] TRACE: < OK
0000126362 [ncp.at] TRACE: > AT+CEREG?
0000126366 [ncp.at] TRACE: < +CEREG: 2,3
0000126367 [ncp.at] TRACE: < OK
0000126368 [ncp.at] TRACE: > AT+UCGED?
0000126374 [ncp.at] TRACE: < +UCGED: 2
0000126375 [ncp.at] TRACE: < 6,2,fff,fff
0000126376 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000126377 [ncp.at] TRACE: < OK
0000141377 [ncp.at] TRACE: > AT+CEREG?
0000141380 [ncp.at] TRACE: < +CEREG: 2,3
0000141381 [ncp.at] TRACE: < OK
0000141382 [ncp.at] TRACE: > AT+UCGED?
0000141389 [ncp.at] TRACE: < +UCGED: 2
0000141389 [ncp.at] TRACE: < 6,2,fff,fff
0000141390 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000141391 [ncp.at] TRACE: < OK
0000156391 [ncp.at] TRACE: > AT+CEREG?
0000156395 [ncp.at] TRACE: < +CEREG: 2,3
0000156395 [ncp.at] TRACE: < OK
0000156396 [ncp.at] TRACE: > AT+UCGED?
0000156404 [ncp.at] TRACE: < +UCGED: 2
0000156404 [ncp.at] TRACE: < 6,2,fff,fff
0000156405 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000156406 [ncp.at] TRACE: < OK
0000171406 [ncp.at] TRACE: > AT+CEREG?
0000171410 [ncp.at] TRACE: < +CEREG: 2,3
0000171410 [ncp.at] TRACE: < OK
0000171411 [ncp.at] TRACE: > AT+UCGED?
0000171418 [ncp.at] TRACE: < +UCGED: 2
0000171418 [ncp.at] TRACE: < 6,2,fff,fff
0000171419 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000171420 [ncp.at] TRACE: < OK
0000185520 [ncp.at] TRACE: < +CEREG: 5,"3875","01452f04",7
0000185521 [ncp.client] TRACE: NCP connection state changed: 2
0000185521 [mux] INFO: Opening mux channel 2
0000186195 [net.pppncp] TRACE: NCP event 100
0000186196 [net.pppncp] TRACE: New auth info
0000186198 [net.pppncp] TRACE: NCP event 2
0000186199 [net.pppncp] TRACE: State changed event: 2
0000186200 [net.ppp.client] TRACE: PPP thread event LOWER_UP data=0
0000186200 [net.ppp.client] TRACE: State READY -> CONNECT
0000186201 [ncp.at] TRACE: > AT+CIMI
0000186203 [net.ppp.client] TRACE: State CONNECT -> CONNECTING
0000186370 [ncp.at] TRACE: < 234104099949476
0000186371 [ncp.at] TRACE: < OK
0000186372 [ncp.at] TRACE: > AT+CPOL?
0000186373 [ncp.at] TRACE: < +CEREG: 0
0000186486 [ncp.at] TRACE: < OK
0000186487 [ncp.at] TRACE: > AT
0000186490 [ncp.at] TRACE: < OK
0000186491 [ncp.at] TRACE: > AT+CGATT?
0000186495 [ncp.at] TRACE: < +CGATT: 1
0000186495 [ncp.at] TRACE: < OK
0000187496 [ncp.at] TRACE: > AT
0000187499 [ncp.at] TRACE: < OK
0000187500 [ncp.at] TRACE: > AT+UPORTFWD=100,1
0000187504 [ncp.at] TRACE: < +UPORTFWD: 100,1
0000187505 [ncp.at] TRACE: < OK
0000187506 [ncp.at] TRACE: > ATD*99***1#
0000367506 [ncp.client] ERROR: Failed to enter data mode
0000367506 [net.ppp.client] ERROR: Failed to dial
0000367507 [net.ppp.client] TRACE: State CONNECTING -> CONNECT
0000367507 [net.pppncp] TRACE: NCP event 3
0000367508 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000367510 [system.nm] TRACE: Interface 4 power state changed: POWERING_DOWN
0000367511 [ncp.client] TRACE: Powering off using AT command
0000367512 [ncp.at] TRACE: > AT+CPWROFF
0000367512 [ncp.at] TRACE: < +CEREG: 3
0000367611 [net.ppp.client] TRACE: State CONNECT -> CONNECTING
0000369893 [ncp.at] TRACE: < OK
0000369893 [ncp.client] TRACE: Waiting to be turned off
0000369934 [net.pppncp] TRACE: NCP event 3
0000369934 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000369935 [system.nm] TRACE: Interface 4 power state changed: DOWN
0000369936 [ncp.client] TRACE: 43 ms to power off the modem.
0000369936 [mux] INFO: Stopping GSM07.10 muxer
0000369937 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000369937 [mux] INFO: Closing all muxed channels
0000369938 [mux] INFO: Closing mux channel 1
0000369939 [mux] INFO: Closing mux channel 2
0000369939 [mux] INFO: Muxed channel 3 already closed
0000369940 [mux] INFO: Muxed channel 4 already closed
0000369940 [mux] INFO: GSM07.10 muxer thread exiting
0000369941 [ncp.client] TRACE: NCP connection state changed: 1
0000369942 [net.pppncp] TRACE: NCP event 2
0000369942 [net.pppncp] TRACE: State changed event: 1
0000369943 [mux] INFO: GSM07.10 muxer stopped
0000369944 [ncp.client] TRACE: Soft power off success
0000369944 [ncp.client] TRACE: Deinit UART
0000369945 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000369946 [ncp.client] ERROR: Failed to enter data mode
0000369946 [net.ppp.client] ERROR: Failed to dial
0000369947 [net.ppp.client] TRACE: State CONNECTING -> CONNECT
0000369949 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0000369949 [net.ppp.client] TRACE: State CONNECT -> DISCONNECT
0000369951 [net.ppp.client] TRACE: State DISCONNECT -> DISCONNECTING
0000369953 [net.ppp.client] TRACE: PPP thread event ERROR data=5
0000369954 [net.pppncp] ERROR: PPP error event data=5
0000369954 [net.ppp.client] TRACE: PPP thread event DOWN data=0
0000369955 [net.ppp.client] TRACE: State DISCONNECTING -> DISCONNECTED
0000369957 [net.ppp.client] TRACE: State DISCONNECTED -> READY
0000370047 [ncp.client] TRACE: Already off
0000370047 [ncp.client] TRACE: Soft power off success
0000370048 [ncp.client] TRACE: Deinit UART
0000370048 [ncp.client] TRACE: NCP connection state changed: 0
0000370049 [net.pppncp] TRACE: NCP event 2
0000370049 [net.pppncp] TRACE: State changed event: 0
0000370050 [ncp.client] TRACE: NCP state changed: 0
0000370051 [net.pppncp] TRACE: NCP event 1
EPS network registration status (read)
Mode configuration (n)	2	network registration and location information URC enabled
EPS registration status (stat)	3	registration denied
This usually means that:
  • The SIM has not been activated
  • The tower has not received the information that the SIM has been activated
  • The tower does not have an operator that is compatible with the SIM
Channel and network environment description (read)
This can occur if the tower has too low of a signal strength to connect.
I don't see anything obvious from those two logs that would definitively say what is wrong.
It appears that registration denied occurred because your SIM attempted to connect to a Verizon tower, and your SIM is not part of an enterprise plan and can only connect to AT&T and T-Mobile.
Thanks for looking into it. Is there any way to tell the device to connect to AT&T or T-Mobile towers instead? All three providers have service where I am.
The device should automatically switch between carriers.
However, your SIM card is awaiting an update, but this can only over cellular. So it is possible that once it finally gets a good connection it will update, and it will then work better in the location it previously did not work, though that is not guaranteed to be the case.
