Does anyone know the dfu-util command to update the bootloader for 0.7.0? I need the memory location to add this to my script.
The line would look like this but I don’t know what goes in the question marks
dfu-util -d 2b04:d006 -a 0 -s 0x??? -D bootloader-0.7.0-photon.bin
BACKGROUND (if you want it)
It is important the target device stay in dfu mode until the entire process is complete. my previous sequence was
dfu-util -d 2b04:d006 -a 0 -s 0x8020000 -D system-part1-0.7.0-photon.bin
dfu-util -d 2b04:d006 -a 0 -s 0x8060000 -D system-part2-0.7.0-photon.bin
particle flash --usb app.bin
(then the unit resets and we go to testing and stuff)
If I don’t update the bootloader the testing code breaks on my production programming machine when the bootloader is updated via the cloud. (it goes to safe mode a period of time)
If I run particle flash --usb bootloader-0.7.0-photon.bin it comes out of dfu mode and my programming sequence doesn’t work.
