Hiya,
I’m having difficulty debugging the bootloader firmware.
From the main function and on debugging works just fine, however I can’t seem to debug any code prior to entry in the main function.
After flashing (via JTAG), gdb enters at main.c:90 0x080001a0, ignoring all breakpoints I place in the SystemInit function (system_stm32f2xx.c).
I’m running make with USE_SWD_JTAG=y DEBUG_BUILD=y (i’ve also tried setting export COMPILE_LTO=n in the makefile).
Being that SystemInit is called before main (see build/arm/startup/startup_stm32f2xx.S), and the -g3 debugging flag is present in the CFLAGS, why is it that my breakpoints are not being hit?
Thank you!
