anybody with a battery shield having problem unplugging the battery?
It seems to be stuck in the shield adn i would not want to brake down everything pulling too hard
Any trick to get it out?
Can you show us a picture of the connector being stuck?
It should come out fairly easily by rocking left and right or if you use a screw driver to push it slightly.
in the end i was able to pull it out with pliers, i think i push it in too hard, lesson learned
