Hello,
I am new using the particle photon and I got the battery shield with a little lion battery I want to connect with the IMU shield to fly with a drone (long story, but it’s gotto be light weight)
however, whenever I connect the battery shield to the particle, the connection gets lost (the light starts to breath green) Whenever i take the battery shield off, I don’t have this problem.
This happens whenever I only connect the battery shield on the particle as well as when it’s connected to the USB cable. I find it hard to google so I hope anyone can help.
Problem is solved. Very basic issue. The tips were touching on the other side of the board somehow, was still covered in the foam so I didn’t notice. Am embarrassed of this issue. Thank you, this topic can be closed.
