# Baby monitor over the internet! web client help?
**URL:** <https://community.particle.io/t/baby-monitor-over-the-internet-web-client-help/43623>\
**Category:** Getting Started\
**Created:** [August 24, 2018, 1:14pm UTC](https://community.particle.io/t/baby-monitor-over-the-internet-web-client-help/43623 "2018-08-24T13:14:37Z")\
**Showing post:** 2
**Author:** ![ninjatill](https://sea2.discourse-cdn.com/flex026/user_avatar/community.particle.io/ninjatill/32/17370_2.png) [@ninjatill](https://community.particle.io/u/ninjatill)\
**Post date:** [August 24, 2018, 1:20pm UTC](https://community.particle.io/t/baby-monitor-over-the-internet-web-client-help/43623/2 "2018-08-24T13:20:54Z")
Check out this post. There are links to 2 github repos by @rickkas7 which demonstrate streaming audio with the Photon over the internet.
> [@Sub-millisecond timer output compare interrupt](https://community.particle.io/t/sub-millisecond-timer-output-compare-interrupt/29401):
> I’ve been toying with an Electron for a while; all going well - thanks largely to this community. Thanks to all… In my application, I’ve written code to sample noise in direct bursts (1000 samples in a loop) to do some post processing (FFT’s etc). However - I would like to make the system a little smarter by allowing continuous noise monitoring (i.e. through at fixed interval timer interrupts). Then post process the noise of there is an event “of interest”. The “Timer” function out of the box …
_[View the full topic](https://community.particle.io/t/baby-monitor-over-the-internet-web-client-help/43623)._
