# \[B523\]\[DeviceOS 3.0.0\] High current consumption during sleep
**URL:** <https://community.particle.io/t/b523-deviceos-3-0-0-high-current-consumption-during-sleep/60736>\
**Category:** Firmware\
**Tags:** boron\
**Created:** [July 12, 2021, 10:14am UTC](https://community.particle.io/t/b523-deviceos-3-0-0-high-current-consumption-during-sleep/60736 "2021-07-12T10:14:59Z")\
**Showing post:** 3
**Author:** ![laughlin](https://avatars.discourse-cdn.com/v4/letter/l/c37758/32.png) [@laughlin](https://community.particle.io/u/laughlin)\
**Post date:** [July 25, 2021, 11:39pm UTC](https://community.particle.io/t/b523-deviceos-3-0-0-high-current-consumption-during-sleep/60736/3 "2021-07-25T23:39:48Z")
I am also experiencing higher-than spec’ed sleep current (610uA measured), but using the Boron LTE Feather module with deviceOS 3.0.0, as noted in my post [here](https://community.particle.io/t/unable-to-achieve-expected-boron-lte-hibernate-current/60568).
There are some others in the Forum experiencing similar with [Argon hardware](https://community.particle.io/t/power-consumption-on-a-sleeping-argon-not-hitting-spec/60779/11) and deviceOS 3.0.0.
There seemed to be lots of [Forum activity](https://community.particle.io/t/boron-deep-sleep-current-increased-in-1-2-1/51138/15) around sleep current issues around deviceOS 1.5.0; Based on the comments at the end of that thread, I may target some older versions and see if there was a regression in terms of sleep current. If I do, I will post my findings.
_[View the full topic](https://community.particle.io/t/b523-deviceos-3-0-0-high-current-consumption-during-sleep/60736)._
