Ok if you promis not to laugh?
To be honest I don’t remember what the last code I entered was, it has been too long and too many frustrations since I last edited the code.
int day = 0;
int Time1[4];
int Time2[4];
int Time3[4];
int Time4[4];
int Time5[4];
int Time6[4];
int Time7[4];
int startHour = 0;
int startMinute = 0;
int stopHour = 0;
int stopMinute = 0;
retained int mode = 0;
int oldMode;
char publishMode[2];
char publishTime1[4];
char publishTime2[4];
char publishTime3[4];
char publishTime4[4];
char publishTime5[4];
char publishTime6[4];
char publishTime7[4];
String str;
//String str2;
int publishModeInteger;
int manualTime = 0;
int timeLastPublish;
int publishDelay = 15;
bool timeTime = false;
bool block1 = true;
Particle.function("parseTime",parseTime);
Particle.function("mode",modeToggle);
Particle.function("manualTime",parseManualTime);
str = String(mode);
if (Time.now() > timeLastPublish + publishDelay && block1) {
sprintf(publishTime1,"1~%i~%i~%i~%i",Time1[0],Time1[1],Time1[2],Time1[3]);
Serial.print("publishTime1: \"");
Serial.print(publishTime1);
Serial.println("\"");
Particle.publish("publishTime1",publishTime1);
sprintf(publishTime2,"2~%i~%i~%i~%i",Time2[0],Time2[1],Time2[2],Time2[3]);
Particle.publish("publishTime2",publishTime2);
sprintf(publishTime3,"3~%i~%i~%i~%i",Time3[0],Time3[1],Time3[2],Time3[3]);
Particle.publish("publishTime3",publishTime3);
sprintf(publishTime4,"4~%i~%i~%i~%i",Time4[0],Time4[1],Time4[2],Time4[3]);
Particle.publish("publishTime4",publishTime4);
block1 = false;
if (Time.now() > timeLastPublish + publishDelay + 7) {
Serial.print("publishTime 2");
sprintf(publishTime5,"5~%i~%i~%i~%i",Time5[0],Time5[1],Time5[2],Time5[3]);
Particle.publish("publishTime5",publishTime5);
sprintf(publishTime6,"6~%i~%i~%i~%i",Time6[0],Time6[1],Time6[2],Time6[3]);
Particle.publish("publishTime6",publishTime6);
sprintf(publishTime7,"7~%i~%i~%i~%i",Time7[0],Time7[1],Time7[2],Time7[3]);
Particle.publish("publishTime7",publishTime7);
str.toCharArray(publishMode,2);
Serial.print("publishMode: \"");
Serial.print(publishMode);
oldMode = mode;
Particle.publish("mode",publishMode);
block1 = true;
timeLastPublish = Time.now();
if (mode != oldMode) {
oldMode = mode;
int parseTime(String command){
char charBuf[20];
command.toCharArray(charBuf, 20);
//Begin black magic supplied by @mdma at:
// https://community.spark.io/t/gpio-control-via-gui/6310/7
const int value_count = 8; // the maximum number of values
int values[value_count]; // store the values here
char string[20];
strcpy(string, charBuf); // the string to split
int idx = 0;
for (char* pt=strtok(string, "~"); pt && idx<value_count; pt=strtok(NULL, "~")) {
values[idx++] = atoi(pt);
//End black magic.
day = values[0];
if (day == 1) {
for (int i = 1; i < 5; i++) {
Time1[i-1] = values[i];
Serial.println(Time1[i-1]);
} else if (day == 2) {
Time2[i-1] = values[i];
} else if (day == 3) {
Time3[i-1] = values[i];
} else if (day == 4) {
Time4[i-1] = values[i];
} else if (day == 5) {
Time5[i-1] = values[i];
} else if (day == 6) {
Time6[i-1] = values[i];
} else if (day == 7) {
Time7[i-1] = values[i];
timeTime = true;
return 0;
int modeToggle(String command) {
if (command=="on") {
Serial.println("On");
mode = 1;
return 1;
else if (command=="off") {
Serial.println("Off");
mode = 0;
return 0;
else if (command=="auto") {
Serial.println("Auto");
mode = 2;
return 2;
else {
return -1;
int parseManualTime(String command) {
Serial.println(command);
manualTime = command.toInt();
Serial.print("Manual time");
Serial.print(manualTime);
Serial.println();
mode = 3;
return 0;
