Authentication Beep/Noise
Hey Everyone,
We’re building an application that involves authenticating with a Phone (NFC)/RFID. We’d like the device to “Beep” based on the RFID/NFC session being authenticated.
Is there a part people have had good success with? We’ll be using this in cold environments (-40F) as well as hot, if that makes a difference.
Best,
Matthew
How does this look? The datasheet says it works in low and high temperature environments.
https://www.digikey.com/product-detail/en/murata-electronics-north-america/PKMCS0909E4000-R1/490-9647-1-ND/4878401
@mblackler I have used a similar piezo device to the one @nrobinson2000 is proposing. It will work OK but may not be loud enough if it is on a PCB which is mounted inside an enclosure. You may need to consider a small op amp to allow a higher voltage to be used than the PWM 3.3V output on one of the pins.
That’s really helpful, thanks. The murata module looks appealing and it I have 12v on hand that I can use.
Time to do some testing!
