I’ve tried to upgrade Atom 1.18.0 to 1.19.0. Unfortunately the automatic update didn’t work. So I downloaded the latest Atom 1.19.0 from particle website and installed it on my Mac OSX 10.12.6.
Since I did the upgrade, I get the following error message:
Atom 1.19.0 says that there are no available update. I’ve tried to google this error to no avail. Any hint how to solve this issue?
Since the upgrade I’ve a bunch of errors when compiling codes that did correctly compile on 1.18.0. And I’m wondering if it is not linked to the above message.
I solved it updating the target firmware through the console.
1.Install the Particle CLI.
2. Set the photon to DFU Mode. (yellow blinking)
3. from the prompt comand : particle flash --usb tinker
4. Set the photon to listening mode (blue blinking).
5. Setup again the wifi connection.
I should have posted also my resolution. Since it is 2 months old, I don’t recall the exact path I took to solve the issue.
However if I’m correct my problem was linked to the fact that the project structure I was using was not compliant with the particle desktop IDE project organisation. And for some reason it only showed up during the last upgrade. I did just reorganized my libraries to comply with these requirement and it did solved the issue*.
