AT Command no response
I tried some AT Commands (AT+COPS) and after that it seems like the GSM Module is not responding any more. Doesn’t matter which command i send i always run into the timeout. Also i am not able to connect to the cloud.
Any ideas? Is there a way to do a factory reset the hardware way?
Hello,
Let me ping someone that might be able to help, @tylercpeacock are you able to assist?
Kyle
I got it back working. I tried a lot. Using MANUAL mode and after some time it started working. Seems like the AT+COPS command is only working after the cellular.ready().
