Good Morning
I have Argon with Firmware 1.5.0 from this Morning is not possible to see the variable on Console same with the Api - call. For this reason I flash app Tinker, first from my Iphone the device blink and go back with the correct - breathing cyan - but nothing appears on cellular and the star continues to turn without to stop.
Any Idea? Thanks a lot
Valentino
Have you tried via DFU Mode and particle flash --usb tinker -v?
What was the output of that command?
Can also watch (and show) what console.particle.io/logs tells you after the device comes back online?
Hi
I’m Flash Tinker from cellular and this work I can see the variable from Tinker.
On Console on my Pc I see no Events. I attach a print screen from Iphone.
I’m flash my code to see if I can see the Variable in Console but nothing.
I do again a Tinker from Cellular and I have the same problem star turn without to stop
Best
Valentino
Hi ScruffR what o you mean if you downgrade the firmware?
Best
Sorry I Flashing the Tinker (command)
