# Argon stuck in DFU no matter what I do
**URL:** <https://community.particle.io/t/argon-stuck-in-dfu-no-matter-what-i-do/56951>\
**Category:** Firmware\
**Created:** [July 12, 2020, 3:58am UTC](https://community.particle.io/t/argon-stuck-in-dfu-no-matter-what-i-do/56951 "2020-07-12T03:58:20Z")\
**Showing post:** 2
**Post date:** [July 12, 2020, 11:46am UTC](https://community.particle.io/t/argon-stuck-in-dfu-no-matter-what-i-do/56951/2 "2020-07-12T11:46:09Z")
> [@coco](#):
> (though I did delete the device from my account…)
This is something the hardly ever solves anything but often enough causes additional issues - so it's best to avoid that.
> [@coco](#):
> I’ve attempted flashing over terminal, did not work.
How did you do that exactly?
You can try
```plaintext
particle flash --usb tinker -v
particle update -v
Additionally to some possible issue with the current firmware state of your device another reason for that issue could be that your MODE/SETUP button got stuck in the connected state or you have something holding the MD pin low.
_[View the full topic](https://community.particle.io/t/argon-stuck-in-dfu-no-matter-what-i-do/56951)._
