Argon Hard fault
I am having trouble with my Argon. I have a Hard Fault and I cannot get it to work. I am new to this microcontroller and I’ce tried using CLI, the device doctor is not working because it says it cannot find the files nor the app and I don’t know if I have to download anything else.
Device doctor does not yet work with Gen3. That and a lot of other Gen3-friendly functionality is coming in CLI.
Were you able to get the Argon set up with the mobile app? If so, have you flashed your own code to it yet? If “yes”, then try putting it into Safe mode and see if you still get the hard faults.
If your code is causing the hard fault then showing that code may help :wink:
